Foaming gun
Old May 24, 2010 | 08:23 AM
MoeMistry's Avatar
Premium Sponsor
Originally Posted by Jean Claude
If you do that, you're going to have soap sitting on the car until you get to it with the mitt. That's a lot of time for the water to potentially evaporate leaving a film/streaks that will be more difficult to remove.
Let's say you foam, rinse, foam again then start mitt washing but wash off the parts that you mitt-wash as soon as you hit them. Now you're wasting product because the water will rinse off soap from the lower portions(as long as you're washing from the top down as you should) and you will be refoaming.
Foaming is nice way to pretreat the surface to break up contaminants. But I choose to not leave my pretreat on long enough for the water to start evaporating. There are exceptions to the rule tho and someone may find in their case it works. Only one way for someone to personally find out.
My take is that you can do it fast or do it right. Those two usually don't walk hand in hand.
+1...well-said. Foam gun is excellent pre-treat for a dirty vehicle. Other than that, nothing beats the ol'fashioned wash mitt and soap bucket.
Old May 26, 2010 | 03:38 AM
illest18's Avatar
illest18 is infamous around these parts
^ now would you use the 2 bucket process? or just one bucket with soap and water?
Old May 26, 2010 | 10:42 PM
Jean Claude's Avatar
Jean Claude is infamous around these parts
2-bucket at all times.
It's there to keep your soapy water and mitt clean.
Old May 27, 2010 | 10:33 AM
markesq's Avatar
markesq has a spectacular aura aboutmarkesq has a spectacular aura about
I have to tell you. I foam, and then use the mitt with grit guard and clean water. If you use the right soap it will work just fine. No film residue and the soap will reconstitute when wet again. I live in Florida, and the soap can dry fast at any time of the day.
If my car is just lightly dusty, I can foam, then rinse without even using the bucket to get the car pretty darn clean.
Old May 28, 2010 | 01:35 PM
illest18's Avatar
^ yeah. im planning on getting a foam gun, havent seen it in person yet.
But if the car still dirty, ill just foam it again. and use a mitt and have a bucket of clean water next to me.
Old May 31, 2010 | 05:15 PM
drdrilz's Avatar
drdrilz is a jewel in the roughdrdrilz is a jewel in the roughdrdrilz is a jewel in the rough
i purchased this foam gun since i cant seem to find the gilmour foamaster at a decent price. i foung it at a local tractor supply co store fo $29.99. it was recommended on autopia. it seems to work well and it has a quick disconnect so you can remove the tank quickly. dont know if you can do that with the gilmour model.
http://www.ezall.com/products/ezfoamer.html
Old Jun 1, 2010 | 03:15 PM
nlpamg's Avatar
nlpamg is infamous around these parts
I got the Gilmour Foammaster II and used it quite a bit. However, it didn't get as foamy as I wanted and it used a ton of water.
So, I got the foam attachment for my pressure washer and it works way better-it suds better and it uses less water.
Gilmour:
Foam lance attachment for my pressure washer:
Old Jun 1, 2010 | 06:07 PM
markesq's Avatar
This is the one I got for my electric pressure washer. Works awesome.
http://www.autogeek.net/autogeek-foam-cannon-hp.html
Old Jun 1, 2010 | 08:19 PM
DetomasoGTS74's Avatar
Mark-I have often wondered about just foaming the car, rinsing followed by using my heated air blower. Mine is only driven on sunny days
What color is your Vantage? I figure on my Tungsten you would not even notice....
Old Jun 2, 2010 | 12:41 AM
illest18's Avatar
Well obviously the cannon attached to a PW will give a shaving cream type of a foam. While the gilmour would be more wattery. Big difference in price and equipment. With the gilmour foam gun did the totally rinse off? Or did you have to scrub the car? And if you did to scrub the car did the dirt particles come off easier?
Old Jun 2, 2010 | 02:14 PM
markesq's Avatar
Onyx Black.
Old Jul 11, 2010 | 09:30 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
I got this foam cannon for my pressure washer.
$20-ish at the Home Depot
http://www.homedepot.com/Outdoors-Ou...atalogId=10053
Works great. And for the price, can't be beat!
