Foaming gun
Old Mar 3, 2010 | 08:32 AM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Foaming gun
Is washing with foaming gun preferable to just regular wash? It certainly appears so given that foam can loosen dirt etc. Anyone recommend a reasonably priced foaming gun and wash?
Thanks!
Old Mar 3, 2010 | 08:51 AM
MoeMistry's Avatar
Premium Sponsor
Thanks!
The foam gun is truly designed as a pre-rinse. You soak the whole car with the foam for a few minutes, rinse, and then resume with the typical bucket washing. This allows the dirt to loosen, as you have already alluded, making it easier to wash a heavily soiled car.
I think Gilmour Foammaster II is a good brand.
Old Mar 3, 2010 | 08:53 AM
sbkim's Avatar
Thanks Moe! Just sounds like an ideal step to add when the car is really dirty.
Old Mar 3, 2010 | 09:00 AM
MoeMistry's Avatar
Premium Sponsor
Precisely...
Old Mar 3, 2010 | 10:52 PM
GlisteningTech's Avatar
Premium Sponsor
GlisteningTech is infamous around these parts
I think that it is a great alternative if the car is really dirty, it gets your process going and starts the cleaning process well before you ever have to lay a hand on the car. That is great for protecting your paint finish, and making your job easier to get everything thoroughly clean.
6speed Members use Promo Code 6speed to receive 10% off entire order
Old Mar 15, 2010 | 11:15 AM
seth_horwitz's Avatar
seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !seth_horwitz Is a GOD !
Is there any reason why you can't use a foam gun in lieu of a bucket? Can't you spray on the foam, and then use a wash-mitt to just scrub the car? (If you're really obsessive, you could rinse the mitt in a bucket of plain water to remove any grit while you work.) Even if you use the bucket for a rinse, you're still saving the "applying soap" portion of the wash, which has to be 30% of the work. Finally, can you use foam as a lubricant for claying a car? I'd think that could save a ton of time. I don't plan on doing anything until I hear from some of the pros.
Old Mar 18, 2010 | 01:36 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Good question. I always thought the same thing. If the car is not really dirty maybe you can skip a step in the process???
Adam
Old Mar 22, 2010 | 04:08 AM
edwinbong's Avatar
edwinbong is infamous around these parts
you would want as much "lubricant" as possible to prevent swirls
Old May 23, 2010 | 01:32 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Bringing this question to the top. Can you foam, rinse, then foam again, this time using a mitt to wash the car?
Old May 23, 2010 | 09:45 PM
Jean Claude's Avatar
Jean Claude is infamous around these parts
If you do that, you're going to have soap sitting on the car until you get to it with the mitt. That's a lot of time for the water to potentially evaporate leaving a film/streaks that will be more difficult to remove.
Let's say you foam, rinse, foam again then start mitt washing but wash off the parts that you mitt-wash as soon as you hit them. Now you're wasting product because the water will rinse off soap from the lower portions(as long as you're washing from the top down as you should) and you will be refoaming.
Foaming is nice way to pretreat the surface to break up contaminants. But I choose to not leave my pretreat on long enough for the water to start evaporating. There are exceptions to the rule tho and someone may find in their case it works. Only one way for someone to personally find out.
My take is that you can do it fast or do it right. Those two usually don't walk hand in hand.
Old May 23, 2010 | 09:53 PM
bonehead's Avatar
Good points! Not necessarily trying to do it fast, but I don't want to make more work for myself either. A proper wash, clay, polish, seal, wax will likely take me an entire weekend (and this is not even touching the interior). With the temps reaching 100+ here everyday, I'm trying to streamline my process and avoid turning into a piece of jerky
Old May 23, 2010 | 09:58 PM
I hear ya. I wasn't trying to imply you were trying to be cheap with your time. Just thinking out loud.
In the case that you're dealing with really hot temps, even in the shade, you're going to struggle with water evaporating using a regular wash. If you don't wash with DI water, make sure to rinse many times through the wash. If it's hot enough, I might even just foam/pretreat just lower panels or the lower front clip.
There's nothing worse than taking your time on a wash and finding out there are soapy streaks. urgh...
Old May 23, 2010 | 10:12 PM
bonehead's Avatar
DI is a must here. Not only is it hot but the water is hard as rocks. My CR's resin depleted without my knowledge and I washed the car....needless to say I have never wiped down a car so fast in my life
Old May 23, 2010 | 10:27 PM
Lemme guess, Arizona?
Old May 23, 2010 | 10:29 PM
bonehead's Avatar
Give that man a prize
