Need advice
Old Aug 29, 2010 | 06:56 AM
4Scargo's Avatar
4Scargo is infamous around these parts
Need advice
Hey, as I said, I need some expert advice. I have an '03 C4S that is a rebuilt. My friend, who is a body man replaced a fender and the bumper covers and then decided to repaint the whole thing. It looks "pretty" good, but I think he lost interest towards the end, as the paint looks a little rough, like 3000 grit sand paper.
What do I do? Where do I buy the products?
I just bought a Porter Cable 7424 (I haven't gotten it yet) with some pads. I plan to practice on my 98 Explorer before I attempt my baby.
Thanks in advance.
Old Aug 29, 2010 | 08:23 AM
Dan1's Avatar
Dan1 has a spectacular aura aboutDan1 has a spectacular aura aboutDan1 has a spectacular aura about
Needs to be wet sanded.
Old Aug 29, 2010 | 09:03 AM
MoeMistry's Avatar
Premium Sponsor
Thanks in advance.
Can you post a few pictures. Without seeing it, it's hard to tell what should be done.
Old Aug 29, 2010 | 10:35 AM
4Scargo's Avatar
Okay, I'll find someone to post some pics (I don't know how...old, ya know....er, old... er) I won't go to Home Depot and buy some sandpaper, yet ; ) I'll try to take pics like they do in the " paint correction" posts.....with a light (?) and a close up? Lead me through this, guys.
But, is there something I should order now? Like, rubbing compound, polish, sealant, wax? I am a little anxious to learn and get going and would kind of like to learn on the Ford when the PC 7424 arrives.
Old Aug 29, 2010 | 01:48 PM
RPGilberts87's Avatar
RPGilberts87 is infamous around these parts
First of all try polishing it first because using the PC is a little more time consuming getting those sanding marks out than it is working with a rotary (which takes time and practice). The PC is a great machine to learn polishing on.
As far as sandpaper goes. Go to an auto supply store like o'reillys cuz they have a hand backing plate (must buy that) and wet sand paper from 600-2000 grit. Make sure and use that backing plate for a more even finish. And alsways finish off with a higher grit sandpaper.
I really like using menzerna Polish's. I have their entire line up. I would think you might need to use an orange LC pad with their Super intensive polish or their Powergloss polish which is like their compound. but try your lease aggressive polish first and if that doesn't work, work another polish. I would recommend going to DetailedImage.com for your supply's
Old Aug 29, 2010 | 05:08 PM
Dan1's Avatar
I really dont think wet sanding your car (especially removing OP) is something you should do with no experience.
Old Aug 29, 2010 | 07:22 PM
4Scargo's Avatar
Thanks again, "an orange LC pad"? Supposedly, when I recieve my PC, I will have 3 pads that come with it...."LC" is 'light cut'? Are all pads color coded? i.e. all orange pads..light cut?
First off we should talk about the Ford, my practice vehicle. It's white, looks good for a 1998. It has very little wax on it (just bought it) and has, what, typical swirl marks and patina. It will be a good canvas to learn on....the P car is next.
What product should I buy to start with
what for the intermediary
and the finish coat
and the final finish coat
PS I am not a **** about this, as per "Teflon wax makes the car look to sterile" I am more, "Holy ****, Dawg, that car has itself soommme shine!" Hear what I'm sayin'? Maybe, "I'm not going for an A+, and A (or even an A-) is good enough for me". I can get the A+ by spending $400, but I chose not to, and will settle for the best job I (we ) can do.
How about Meguire's stuff?
Let me know
I should get some pics up on Tues.
Old Aug 31, 2010 | 10:54 AM
LC is Lake COunty, just the manufacturer that makes those pads. I've also heard the surbuf pads are great with the PC.
All pads are color coded... Orange is for cutting, white is for polishing, black and blue is for finishing and red is for applying a sealant.
If I was you I'd get the meguairs M105 and M205. M105 is the compound that cut's more and it dries quick so be careful and watch it. M205 is more of the polish that shine's your ride up! If you don't knwo what your doing I'd really recommend taking it to a professional
Old Aug 31, 2010 | 11:03 AM
MoeMistry's Avatar
Premium Sponsor
and the finish coat
Let me know
If this is the case, just get some Menzerna Power Finish and some Power Lock Sealant and call it a day. You can use a LC White pad with the power finish and a red pad with the power lock using your PC. This set up will give the shine you're looking for without the expense of time or money, Dawg
Old Aug 31, 2010 | 12:48 PM
DetailedDesigns's Avatar
DetailedDesigns is infamous around these parts
Not necessarily.
I have fixed cars that had sanding marks, that were as the OP described, with just a Makita and a Flex.
OP, if you can't fix the sanding marks yourself, take your car to a professional. I would suggest getting 3 different opinions on it before you have someone sand it.
Old Aug 31, 2010 | 12:49 PM
MoeMistry's Avatar
Premium Sponsor
Originally Posted by detaileddesigns
not necessarily.
I have fixed cars that had sanding marks, that were as the op described, with just a makita and a flex.
Op, if you can't fix the sanding marks yourself, take your car to a professional. I would suggest getting 3 different opinions on it before you have someone sand it.
+1..
flewis763
Oct 4, 2015 04:14 PM
gjpearce
Sep 30, 2015 04:26 AM
NBoost
Detailing
Sep 29, 2015 10:06 PM
lgl314
Sep 28, 2015 04:17 PM
dynamic gt2
Sep 28, 2015 03:40 PM
