restore Headlights
Rating: Thread Rating: 2 votes, 5.00 average.
Old Oct 25, 2010 | 02:39 PM
tomcat14623's Avatar
tomcat14623 is infamous around these parts
restore Headlights
I've tried the DIY kit, worked hard but the result was poor. I've spoken with a local shop and they wanted $100 for the headlight to be restored (Northern NJ). Is this a fair price ?
Old Oct 25, 2010 | 02:41 PM
Gungriffin's Avatar
Gungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant futureGungriffin has a brilliant future
Is the issue pitting in the lens or yellowing of the lens? Or both?
Old Oct 25, 2010 | 02:45 PM
Yellowing of the lens for sure. I dont know what pitting in the lens means though ?
Old Oct 25, 2010 | 02:52 PM
Gungriffin's Avatar
Pitting is the very very small chips for lack of a better word.
$100 for refinishing the lights is about fair market if they sand them down and compound and polish them with a buffer. Keep in mind that the yellowing is caused by a breakdown of the UV finish on top of the lens. Once they start to yellow that coating is gone. Even after you refinish them it will not take as long for them to yellow again the next time as it did from the time when they were new.
Old Oct 25, 2010 | 03:09 PM
I see, no pitting from what I can tell. The shop said they will do a 9 step process and can also clear coat it to finish off. I suppose this will keep it from yellowing again for quite some time?
Old Oct 25, 2010 | 03:16 PM
Gungriffin's Avatar
A good clear coat should give you at least 2 years before you see any yellowing again.
Old Oct 25, 2010 | 06:52 PM
RPGilberts87's Avatar
RPGilberts87 is infamous around these parts
9-step process? sounds like their trying to sell you something rediculous.. Honestly if they have a good rotary most likely they can polish the yellowing out. If they need to wet sand than a good polish and top off the good polishing with a plastic wax (clear or white)
Old Oct 25, 2010 | 07:20 PM
MaximumMD's Avatar
MaximumMD is infamous around these parts
Will regular car wax or paint sealant work to put over the headlights or do you need a plastic specific wax to last long and how long would the it last?
Old Oct 25, 2010 | 08:17 PM
I see, thanks for all the info and advice. I'll go with this shop and make sure they do the clear coat.
Old Oct 26, 2010 | 08:48 AM
MoeMistry's Avatar
Premium Sponsor
9-step....that's a new one. A simple sanding and a few stages of polishing should do the trick. Protecting the lenses with a sealant or wax will also prolong the againg and yellowing.
Old Oct 26, 2010 | 10:37 AM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Harbor Freight has a lens kit for around $15-20 if you are a DIY type person....
-Eli
Old Oct 28, 2010 | 03:31 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
Headlight Protection
Prevention is always better than a cure; with the average cost of replacement head lamps and fog lamps spiralling to nearly $500, it is nice to know that there is a product available to protect your car against the perils of the open road.These products are made from a proprietary, scratch-resistant, urethane material coupled with the strongest optically clear adhesive available
Protect your expensive headlamps, before it's too late. LampGard™ uses a tough 40 mil thick, double-polished urethane material that is optically clear and applies (peel & stick) directly to the surface. This product has built-in ultraviolet inhibitors that help prevent the material from drying, hardening or discolouring. Custom die-cut to fit your specific vehicle for a precise, perfect fit, it comes with easy-to-follow instructions and applies to headlamps, fog lamps, turn indicators and parking lights (when applicable) to protect them from scratching, cracking and pitting. LampGard™
a) Designed for maximum durability, these light covers were originally tested under the harshest of circumstances with amazing results. Both in the real world and in the lab, our covers have proven that they will withstand a barrage of 1" diameter stones (about 1oz.) at speeds up to 120 M.P.H. with no damage to the lens they protect. It is nice to know that your expensive lenses are protected in every scenario. We are so confident in our product that we offer a 5-year warranty to leave you with complete peace of mind. XPEL™ Headlight protection film can also improve the look of old headlights by reducing the haze build-up –Xpel
b) Headlight Armor offers a full line of Premium Lighting Protection Kits as well as a line of Smoked Taillight Film Kits. Made from a tough impact resistant material that is designed to protect your vehicle's lighting, while being self install friendly
Maintenance – wash, dry and apply UVR protection (303 Space Protectant)
Old Oct 28, 2010 | 09:50 PM
XPEL's Avatar
XPEL is a jewel in the roughXPEL is a jewel in the roughXPEL is a jewel in the rough
Agree with Moe But...
We partnered with Mothers and our logo is on the front of their headlight repair kit box. You can go a step further to protect the lenses and use our headlight protection kits as opposed to a sealant or wax. Our kits will prevent your headlight from fogging/yellowing over time. They are also built to withstand impacts of stones up to 1 inch in diameter at 120mph without causing any damage to the lens that they protect.
http://www.xpel.com/products/headlight_protection.asp
airbusdrvr
Dec 27, 2015 07:43 PM
calexand
Nov 5, 2015 01:05 PM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
ECS Tuning - VW
Sep 25, 2015 10:48 AM
ECS Tuning - VW
Sep 25, 2015 07:55 AM
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
