Dirty Stitching
Old Nov 10, 2010 | 10:40 PM
solidst8's Avatar
solidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud of
Dirty Stitching
Some of the golden stitching on the center console has gotten dirty. Anything you guys can suggest I try to remove it?
Old Nov 11, 2010 | 08:34 AM
MoeMistry's Avatar
Premium Sponsor
A few applications of autoglym interior cleaner should do the trick.
Gently spray into stitching, allow to sit, spray on mf towel and begin rubbing. You may have to so this a few times.
http://www.glisteningperfectionstore...ttle%2C/Detail
Old Nov 11, 2010 | 10:49 PM
solidst8's Avatar
Thanks Moe. I shall give that a try.
Old Nov 12, 2010 | 08:59 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
An old toothbrush with your cleaner can help loosen the crud that can build up on stitching. Just don't go crazy with the scrubbing.
Old Nov 13, 2010 | 02:52 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
Leather stitching is usually cotton and nylon mix, nylon is attacked by solvents, they melt it and weaken the threads. An oil-based product will attract abrasive dirt and permeated the leather via the stitching, the oil will soften the leather, and the abrasive dirt plus friction may cause the leather to tear and / or the stitching to fail. Do not use a solvent-based cleaner as this may cause the stitching to fail over time
Stitching is somewhat friable if subjected to excessive abrasion. Bearing this in mind the cleaner needs to ‘do the work’ without relying on friction; clean stitching using a medium / hard horse hair brush, a toothbrush or a sponge, spray and work the water-based cleaner into a foam or use Leather Masters™ Foam Cleaner, lightly rub surface and immediately wipe with a terry towel to remove excess moisture. You may need to repeat this process.
Old Nov 16, 2010 | 10:43 PM
wizness's Avatar
wizness is infamous around these parts
I def agree with this. I bought some autoglym from Moe awhile back and it works great. By far the best cleaner I've used. Makes leather look new again. I spray it..use a swissvax brush to agitate then rub with a cloth or microfiber.
Old Nov 16, 2010 | 10:51 PM
wizness's Avatar
here's an example..the front part is done the back is not..and the 2nd pic is the center console all done
Old Nov 17, 2010 | 07:48 AM
MoeMistry's Avatar
Premium Sponsor
Looks great. Good job.
ZZinger
Cayenne Turbo
Oct 2, 2015 05:39 AM
cherplex
Oct 1, 2015 08:30 PM
Mico
Sep 26, 2015 03:04 AM
ECS Tuning - VW
Sep 22, 2015 11:22 AM
ECS Tuning - VW
Sep 17, 2015 08:44 AM
