Prepping for a detail question
Old Apr 21, 2011 | 02:20 PM
Karrera4's Avatar
Karrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to allKarrera4 is a name known to all
Quick, easy question. When I am prepping the car for an exterior detail I usually wash with a citrius based shampoo that strips the wax, then dry before either claying or polishing. However, I have seen some pictures where it looks like people just wash, rinse and clay without the drying step...is that true? Could I save myself a drying step by just claying after the prep wash and rinse? Thanks.
Old Apr 21, 2011 | 02:33 PM
jzarrabi's Avatar
jzarrabi has a spectacular aura aboutjzarrabi has a spectacular aura aboutjzarrabi has a spectacular aura about
Im no pro but it would make sense to me considering that when you clay the paint you want to make sure that it is well lubed... I dont see how water could hurt.
Old Apr 21, 2011 | 04:16 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
I dry my car completely before claying so I can see and focus on troubled areas better.
Old Apr 21, 2011 | 06:04 PM
Dan1's Avatar
Dan1 has a spectacular aura aboutDan1 has a spectacular aura aboutDan1 has a spectacular aura about
Either way is fine really. Heres my process when the whole car is being clayed. (done out of direct sunlight/ in the garage)
Wash, rinse, clay, rewash with filtered water, blow dry...
So no drying between washing and claying.
Old Apr 21, 2011 | 06:26 PM
MoeMistry's Avatar
Premium Sponsor
If you leave the water on the car, you're diluting the concentration of the lube you're using and may actually marr or scratch the paint. We ALWAYS dry the car prior to claying. You then can rinse or use the same towel you used to dry the car, to wipe the paint of the clay lube. Ideally, Wash-Dry-Clay-Rinse-Dry
Old Apr 21, 2011 | 06:38 PM
Dan1's Avatar
True, good point Moe. Dilution rates should be adjusted accordingly.
Old Apr 22, 2011 | 04:31 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
I'm not so sure that dilution (within reason) would affect the clay lube as your looking to aquaplane the clay using a little surface lubrication
Sep 10, 2015 03:20 PM
Sales@RSW
Sep 3, 2015 09:34 AM
Gewgaw
Aug 19, 2015 11:52 PM
