Ceramic Disc Pads
Old Aug 9, 2013 | 07:24 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
Ceramic Disc Pads
Asbestos pads caused health issues and organic compounds can’t always meet a wide range of braking requirements. Unfortunately the steel strands used in semi-metallic pads to provide strength and conduct heat away from rotors also generate noise and are abrasive enough to increase rotor wear. Wear also cause ferrous oxide dust that looks unsightly and is also corrosive. First used as original equipment manufacturer (OEM) in ’85, friction materials that contain ceramic formulations
Ensure that the ceramic brake pads and rotors match (a ceramic system) otherwise you will have problems with stopping when the pads / rotors are cold or wet, which could warp the rotors and cause bearings to fail due to overheating.
Although a ceramic brake disc absorbs heat faster than a steel brake disc, it is also able to disperse it quickly. A consistently high braking performance is therefore guaranteed.
One of the characteristics that make ceramic materials attractive is the absence of noticeable dust. All brake pads produce dust (including ceramics) as they wear. The ingredients in ceramic compounds produce a light coloured dust that is much less noticeable and less likely to stick to the wheels. Consequently, wheels and tires maintain a cleaner appearance longer.
To avoid brake-generated noise and dust brake friction materials have evolved significantly over the years, going from asbestos to organic to semi-metallic formulations. Each of these materials has proven to have advantages and disadvantages regarding environmental friendliness, wear, and noise and stopping capability.
Using ceramic compounds and copper fibres in place of the semi-metallic pad’s steel fibres, allows the ceramic pads to handle high brake temperatures with less heat fade, provide faster recovery after a stop, and generate less dust and wear on both the pads and rotors.
From a comfort standpoint, ceramic compounds provide much quieter braking because the ceramic compound helps dampen noise by generating a frequency beyond the human hearing range. Another characteristic that makes ceramic materials attractive is the absence of noticeable dust. All brake pads produce dust as they wear. The ingredients in ceramic compounds produce a light coloured dust that is much less noticeable; consequently, wheels and tires maintain a cleaner appearance longer.
Ceramic pads meet or exceed all OEM standards for durability, stopping distance and noise. According to durability tests, ceramic compounds extend brake life compared to most other semi-metallic and organic materials and outlast other premium pad materials by a significant margin; with no sacrifice in noise control, pad life or braking performance. What is important though is that car's rotors are designed for ceramic pads; otherwise the rotors will typically wear faster. (Check with the vehicle manufacturer)
Avoid using any products that contain silicone as it can permeate the carbon-ceramic material and negatively affect the friction and thereby the braking efficiency.
Stopping Distances
At the speeds that stopping distance is generally measured from (60 to 70 MPH), the test is primarily testing the tyres grip on the pavement. As delivered from the manufacturer, nearly all vehicles are able to engage the ABS or lock the wheels at these speeds.
Therefore, an increase in braking power will do nothing to stop the vehicle in a shorter distance. For this reason, we do not record stopping distances at this time. The Brembo brake systems will show their greatest advantages when braking from higher speeds, or when tasked with repeated heavy braking.
Cleaning
Any diluted car wash concentrate, d-limonene (citrus) based cleaner (P21S® High Performance Total Auto Wash) or pH neutral cleaner (P21S Wheel Cleaner) should be fine to use on ceramic brakes as they produce very little brake dust (being non-metallic) they just attract the normal amount of road dust, dirt and grime
TOGWT® Autopia Detailing Wiki articles - http://www.autopia.org/forum/autopia-detailing-wiki/136815-togwt%AE-detailing-articles-index-hyperlinks.html
I hope these TOGWT Detailing Wiki articles will become an asset to anyone who is new to detailing and to the professionals; enthusiast detailer’s and industry experts who seek to advance their knowledge of detailing entry level enthusiast, but to professionals and industry experts as well.
XLR82XS
Oct 5, 2015 07:02 AM
Goonie
Sep 12, 2015 02:10 AM
mjdVantage
Sep 5, 2015 07:22 PM
