Using Detailing products
Old Oct 6, 2015 | 06:26 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
Before using detailing products -
http://togwt1980.blogspot.co.uk/2015...-products.html
Before using detailing products check the following-
Car care chemicals are the most misunderstood component auto detailing, they should work on their real merits, not ‘smoke and mirrors'. Proceed with this in mind; the products you use constitute a very small factor in the equation. It is my opinion that when it comes to car care products its best to understand the scientific process to enable the best result possible.
Most companies won’t release ingredients other than what's on the MSDS sheet. Patenting chemicals is pretty risky since if you change a couple of ingredients by a few percentages it's technically a different product. When it comes to technical specifications and chemical formulations, it is important to realize that all companies must keep secure their proprietary information and agreements. Without this, no business would have the incentive to develop new products, expand their market, stay competitive, and ultimately - exist.
A product that shows great results in the controlled environment of a laboratory may not produce the same results in the real world, this is the reality of field testing, which throws up masses of variables which lab testing just cannot replicate i.e. resistance of paint coatings against ultra violet (UV) damage, bird droppings, acid rain, alkaline sprinklers, scratching (regardless of hardness factors) gloss, dirt and surface stain repellence and temperature resistance.
Detailing relies on the correct preparation procedures and the correct methodology to obtain pristine results. Methodology and technique constitute 95%; the reasoning behind the choice of quality products is to eliminate any limiting factors, thus enabling you to place emphasis on technique used.
riverflyer
Sep 1, 2015 04:22 PM
4ocious
Sep 1, 2015 06:44 AM
k-lo
Cayenne 958
Sep 1, 2015 04:51 AM
