360 spyder f1 transmission newbie question
Old Sep 21, 2010 | 07:31 PM
Plexiform's Avatar
Plexiform is infamous around these parts
I test drove a 2004 360 spyder today and was having issues with the transmission. When in auto mode it popped out and went in to neutral without my initiating it, and when in manual mode when switching from 1st gear to 2nd gear it just went straight in to 4th gear. Is the transmission usually this finicky or was I doing something wrong or does this car have some issues? My brother is looking to buy it but not if this is a serious transmission issue. Thanks for your advice.
Old Sep 21, 2010 | 07:45 PM
MrBucket's Avatar
MrBucket is infamous around these parts
I have heard of them going into neutral if the clutch is worn.
Old Sep 21, 2010 | 07:54 PM
nsxsupra's Avatar
nsxsupra is infamous around these parts
Sounds like it may have transmission issues. I would avoid this car, the F1 tranny is known to be a lot higher maintenance than manual. Unless absolute must, I would avoid pre-430 F1s period.
Old Sep 24, 2010 | 07:28 AM
4RECAT's Avatar
4RECAT is infamous around these parts4RECAT is infamous around these parts
First of all, you should never actually USE the automatic button! Ask any Ferrari tech! Also it is harder to drive it in automatic mode.
Second, my F1 would shift into neutral when I was due for a new clutch. Hasn't done it since!
Old Sep 24, 2010 | 08:24 AM
MK4lowIRA's Avatar
MK4lowIRA is infamous around these partsMK4lowIRA is infamous around these parts
Did they give you the percentage of clutch wear? That could answer your question right there!
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
MrNurse
Sep 10, 2015 09:44 AM
MrMiggy
Aug 21, 2015 06:55 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
