F1 Transmission Light, couldnt shift gears, Help!!!
Old Dec 12, 2010 | 05:47 AM
TWIN_TURBO's Avatar
TWIN_TURBO has a spectacular aura aboutTWIN_TURBO has a spectacular aura about
Hi guys i need help please.
THe F1 360 was in my garage, i turn on the car last night to go out, i shift in reverse gear, and when i get down to the garage (is a incline garage, not too much) the car shut off, i start the car again, i saw the the transmission light remains lit, the transmission went to neutral and I couldnt shift gears any longer. The same day i used the car with no problems at all the only that i make when my car was in the garage is open the hood, close the hood and that's it.
I check the F1 Pump and fuse, fuse Gearbox, i check the Fluid level, all is fine, disconnect the battery,reconect again and wont take shift gears, only in neutral.
I seems like my car is breakdown, like i was the thief and the car shutoff and wont drive the car only start the engine but can drive!!!!
Need help please, today is a sunny day and i want to use the car, help please.
My car was runs great i dont know what happen.....
Old Dec 12, 2010 | 07:41 AM
TWIN_TURBO's Avatar
Hi guys, i forgot to mention that when the car shuts down, i can get out to the drivers door beacuse is lock out, and i have to open the window and open from the outside.
THanks.
Old Dec 12, 2010 | 11:57 AM
MK4lowIRA's Avatar
MK4lowIRA is infamous around these partsMK4lowIRA is infamous around these parts
Should probably get it somewhere to get the error checked, sounds like you need some further diag.
Old Dec 12, 2010 | 01:29 PM
TWIN_TURBO's Avatar
i need someone to check the code using a scan tool, maybe is a sensor, anyone?
Vicelord
Ferrari
17
Jan 26, 2017 12:50 AM
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
GSR Autosport
Aug 26, 2015 05:20 PM
The Oss
Aug 24, 2015 08:19 PM
