360 timing belt change
Old Jul 25, 2015 | 06:12 PM
EspritNOOB's Avatar
EspritNOOB has a spectacular aura aboutEspritNOOB has a spectacular aura aboutEspritNOOB has a spectacular aura about
Hi Everyone I'm in the market for a 360 and concerned with the timing belt service. 360's do not require engine service like its older siblings yes? If yes what would something like this cost on average? What should I look for mechanically and what are some of the quirks I can expect?
Thanks in advance.
Old Jul 27, 2015 | 12:21 PM
Porsche_911's Avatar
Porsche_911 is infamous around these parts
The link below should give more information.
http://www.ferrarichat.com/forum/360...sed-360-a.html
Belts change are not that bad and can be done at home with several beers and lots of patience. There are two timing belts and 3 accessory belts. I did this recently on my 360. I bought the 30k maintenance kit which something you should do (if the previous owner haven't done in the last 3 years). This has all belts, seals and spark plugs. Typically cost around $1,200.
Have fun 360s are fun cars and very reliable.
Old Jul 29, 2015 | 07:44 AM
EspritNOOB's Avatar
Great thanks for the reply!
I will dig more in to it this weekend when I meet up with the seller.
Thanks,
Old Jul 30, 2015 | 06:24 PM
sc170's Avatar
sc170 has a spectacular aura aboutsc170 has a spectacular aura about
Dealers will charge around 5K for a full major service: Belts, fluids, etc.
Indy shop around 2.5k
This only needs to be done every 3-5 years depending on how much you drive. Otherwise just fluids annually.
Just make sure to get a clutch and rotor/pad read out. These too will cost if they need to be replaced.
Good Luck!
Old Jul 31, 2015 | 08:02 AM
EspritNOOB's Avatar
Good Luck!
Got it thank you! Found a shop locally called Raging Bull who did some work on my Esprit and can do the job for about what you are saying.
Thanks!
COBB Tuning
Jan 1, 2025 09:02 AM
00aston
Aug 27, 2015 12:01 AM
