Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Country Home "Man Cave"...
Old Mar 27, 2013 | 08:05 PM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
We have a beautiful country home on the lake which has a rather large garage. The Garage is essentially separated into 2 parts as illustrated below...
While the house itself is beautiful the garage was just that. The original owner was a wood worker and the garage was used as his work shop. Nothing fancy just function. I was thinking about taking the wall down and making the entire garage a "Man Cave" but the fact that I need a place to store the boat, snow blower, ATVs, Snow Mobiles etc made me come to the realization that I am bet to keep the large portion as is and concentrate on the smaller 17x23 portion.
Old Mar 27, 2013 | 08:20 PM
NTIMD8's Avatar
It should be noted that this will be a modest garage (nothing too crazy) and I am doing all the work myself so I have a lot of learning to do.
Here is the entire garage...
The portion I am going to leave alone. It will be used for normal cottage use...
Here is the side that I am going to make into my man cave...
In this pic the gutting has already took place.
Here are the shelves and cupboards we took out...
Garbage...
These I am going to keep. Paint them black with new handles and will use on this side of the garage for storage.
Here you can see the condition of the walls. Lots of time consuming work is going to need to happen to get it how I want it...
Here are some pictures of after the first tape and mud coat one one side...
Here is a before and after of the same corner....
Old Mar 27, 2013 | 08:25 PM
NTIMD8's Avatar
Niches cut out and framed that will hold some art work...
Old Mar 27, 2013 | 08:28 PM
NTIMD8's Avatar
Finished the 1st coat of mud, replaced all drywall that was not fixable and patched sections that were missing drywall. Next is a light sand then a second coat of mud and then another slight sanding and final coat of mud and final sanding. The ceiling is not going to be fun.
Old Mar 27, 2013 | 08:36 PM
NTIMD8's Avatar
This is the box I am going to use for the main light. It is currently 12" thick but I am going to modify it to be 6" thick and going to paint it black since the garage is going to be grey and black.
Cut the light box down to 6" and removed the backing from the portion I am not going to use...
Attached the backing to the portion I am going to use...
Affixed the light fixture into the light box...
Old Mar 27, 2013 | 08:40 PM
NTIMD8's Avatar
The wiring is all done. All the wiring that was outside of the walls have been removed, added switches and plug boxes and wired up the main light source, the track light and the pot lights.
The main light sourece wired in. I will remove the 2 boxes and patch the drywall once the car and trailer are out of the garage.
Wiring for the pot lights in the niches...
Old Mar 27, 2013 | 08:43 PM
NTIMD8's Avatar
With any luck enough snow has melted so that I can move the Porsche to the other side of the garage and take the trailer out so I can work on the ceiling.
Old Mar 30, 2013 | 05:48 PM
NTIMD8's Avatar
Drywalled the niches and got the second coat of mud on. Also got rid of the ugly wood that was around the bottome of the walls.
Old Apr 6, 2013 | 07:45 PM
NTIMD8's Avatar
First coat of mud/tape on the niches. Used plastic corner pieces for the outside corners. What a pain...
Old Apr 7, 2013 | 05:28 PM
NTIMD8's Avatar
Second coat of mud on the niches. Man this part is not fun.
Old Apr 20, 2013 | 02:52 PM
NTIMD8's Avatar
Coat number one billion on the niches. Kill me! lol
Old Apr 28, 2013 | 07:07 PM
NTIMD8's Avatar
Last coat of mud before sanding. The the cieling and then primer and more mud. Way more work than I thought it would be...
Pot lights in...
Old Jun 9, 2013 | 10:44 AM
NTIMD8's Avatar
Ceiling almost done. I can see the light at the end of the tunnel.
Old Jun 9, 2013 | 10:51 AM
0-60freak's Avatar
0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light0-60freak is a glorious beacon of light
You better put some very heavy texture to cover up the tape and float job
Old Jun 9, 2013 | 07:17 PM
NTIMD8's Avatar
Ya for sure. There are a couple of first coat products that smoothen out the imperfections. Im going to use a couple of coats of that stuff first.
