Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
QuickJack 3500 or 5000?
Old Dec 29, 2015 | 02:29 PM
  #31
Jorge Ruiz's Avatar
Jorge Ruiz is infamous around these parts
How are they working out?
Hi guys,
I'm about to pull the trigger and order the new Quickjack 5000SLX but wanted to see if anyone had anything negative to say about it.
I own a 2002 GT2 and my primary purpose for this product will be so I can keep the car raised during longer storage times (avoiding flatspot issues).
Thanks!
Old Dec 29, 2015 | 04:47 PM
  #32
stltri's Avatar
stltri has a spectacular aura aboutstltri has a spectacular aura aboutstltri has a spectacular aura about
Originally Posted by Jorge Ruiz
Hi guys,
Thanks!
What is the distance between the jack points in your car (ie, between front and rear points). As I found out, the 5000XL is too long for a 993 or older 911. Works on a 997, but not sure on a 996 like yours.
As far as your planned use, not sure how long you can keep them on the hydraulics, but certainly you can use the locking bars. But I'm not sure if these jacks were designed for long term storage. You may want to ask Ranger/Bendpak and keep us posted. I'm also curious.
Old Dec 29, 2015 | 06:05 PM
  #33
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
What is the sizing of older 911 and 993?
Old Dec 29, 2015 | 07:59 PM
  #34
Jorge Ruiz's Avatar
It is approximately 54.5" on my 996. The technical specs on the Quickjack 5000slx shows range of 31.5"-60". I'm not so concerned about fitment issues since I've seen a few pics with it... it was more for how I plan to use it (lifted position on a locking bar for extended periods of time).
Old Jan 12, 2016 | 06:50 PM
  #35
r6vr6's Avatar
r6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to all
I got a 5000xl 110 v. It works well so far. I have lifted the car a dozen or so times playing with it. The car is setting on there for winter now. I bought 4 hockey pucks to use along with the blocks that are supplied. The kit comes with every thing you need to get it going other than 2 qts of ATF.
Shipping crating:
Parts basically all you have to do is put these on the lines and hardware:
unit assembled: make sure you run it up and down some before using it. Also in a cold garage it does not like to go down unless there is weight on it.
with the car on it:
with the suv kit extensions:
Old Jan 13, 2016 | 09:10 AM
  #36
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
How many inches does the car move back from ground level to full height? I am also worried about how much room I have in my tight garage.
Old Jan 14, 2016 | 06:17 PM
  #37
r6vr6's Avatar
Full up not on locks it moved my car back 11.75". On the full up lock position I measured 9.5 " rearward from the tires on ground position.
Old Jan 14, 2016 | 07:52 PM
  #38
turboslut's Avatar
Much obliged!
Old Jan 14, 2016 | 07:53 PM
  #39
r6vr6's Avatar
No problem that is what forums are for. So is it going to fit?
Old Jan 14, 2016 | 08:04 PM
  #40
turboslut's Avatar
True that.
Yes...I have enough room, and I am going to order at the end of the month.
Old Feb 3, 2016 | 09:17 AM
  #41
jjurroz's Avatar
jjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant future
is there enough clearance to pull the engine from a 996/997 using the Quickjack 5000SLX + suv extension? (looks like the suv extension gives you higher height.
Old May 18, 2017 | 01:20 PM
  #42
Xander's Avatar
Xander is just really niceXander is just really niceXander is just really niceXander is just really nice
Bumping an old thread, because I have exactly this^^^^ in mind. I know it says 21" lifting height with stacked blocks, and IIRC I need 32.5" to clear the back bumper, so we should fit....
x...
Old Dec 3, 2017 | 07:53 PM
  #43
David Ferguson's Avatar
David Ferguson is infamous around these parts
Love quick jacks
Originally Posted by scatkins
Been investigating Jacks for my 991 Porsche C2S.. as well as other cars
Don't have the space for a 2 post, and I like the Max Jack but, my garage slab probably doesn't meet it's safety requirements for the studs/Bolts. Probably also a bit more trouble than I'd prefer for occasional tire, brake etc work..
I like the QuickJack 3500 or 5000 as it seems very portable and I can store away.
However, from a couple of comments I saw, the QuickJack has a span for the rubber bumpers of only 50.5" which apparently makes it unsuitable for many 911's.. The comment I saw was a 997 needed 54" minimum between jackpoints. I'm also assuming the 991 is similar (haven't measured yet).
Anyone have any experience with the QuickJack and Porsches?
I have the 5000 and they fit my 991 with room to spare.
Old Jun 16, 2020 | 06:25 PM
  #44
anasu98's Avatar
anasu98 is infamous around these parts
Quickjack price
I was going to order one from Costco after I move to a new place since they had the most competitive price which was $999 and just checked Costco.com and it says $1199. Do they normally have its price up and down like this?
where would be the best place to buy a Quickjack you think?
silversrt
Jan 24, 2016 03:45 PM
Let's turn off TC
Oct 27, 2015 08:13 AM
dc3843
17
Oct 1, 2015 04:30 PM
JMAT
Sep 18, 2015 12:15 PM
