Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Waterproofing Garage Walls
Old Aug 18, 2006 | 03:57 PM
BCS996TT's Avatar
BCS996TT is infamous around these parts
Guys... Im building a new home and of course one of my projects is the garage....
What did you use to waterproof your walls? I will be washing the cars in the garage so a section of the walls will need waterproofing.
Any ideas?
Old Aug 18, 2006 | 04:06 PM
SANDOVAL's Avatar
Banned by Moderators
SANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura about
First off what material are the walls made up of?
Old Aug 18, 2006 | 05:01 PM
BCS996TT's Avatar
just standard 5/8 drywall....
Old Aug 19, 2006 | 12:58 AM
SANDOVAL's Avatar
Read this....
http://www.askthebuilder.com/printer...ocations.shtml
Then check out...
http://www.seal-krete.com/forwalls.htm
If your plan is to use your garage as a car wash stall I would not drench your walls. Doing these two steps should help with water mist/splash. If you expect the walls to get real wet then you need to do the following. Also use a rubber base.
If I were doing this for my garage I would use green board, seal it with Seal Krete and then I would use either roll vinyl/Lynoleum 4' high or so along the wall. Or you could use the 12" or 18" tiles to accomplish the same thing. Either way you need to create a barrier from the water.
Old Aug 19, 2006 | 09:40 AM
BCS996TT's Avatar
Thanks....
Any good leads for garage tiles?
Old Aug 19, 2006 | 04:41 PM
Mussel Kar's Avatar
Mussel Kar is a jewel in the roughMussel Kar is a jewel in the roughMussel Kar is a jewel in the rough
You can also apply FRP panels to the walls. Colors are limited but the protection is excelent along with great impact resistance.
Old Aug 22, 2006 | 05:01 PM
canadaisintexas's Avatar
canadaisintexas is infamous around these parts
Depending on the look you want the garage to have you could also use stone of some sort or red bricks on the inside of the walls that could potentially become soaked
Rob
VID997
97
Mar 20, 2018 02:23 PM
MadWhip
Sep 13, 2015 01:27 PM
dealy663
Sep 13, 2015 08:57 AM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
studio112
Sep 7, 2015 05:06 AM
