Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Driveway Question...
Old Jul 17, 2007 | 06:52 PM
TunaRollZ's Avatar
TunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of light
Originally Posted by D-UberCars
A couple of pix for the faux green slate driveway and patio for the works in progress garage project.
http://www.flickr.com/photos/9095169@N06/
love the slate, LOVE the lift.
Old Jul 18, 2007 | 10:02 AM
H007H's Avatar
H007H is infamous around these parts
One word:
SUNDEK
www.sundek.com
Sunstamp is probably one of the best products ever made in terms of Stamped Concrete Overlay, and this company started Decorative concrete back in the 1970's. Been in business for 37 years.
GREAT STUFF!!!.
Hope this helps.
Old Jul 18, 2007 | 12:39 PM
Turbochris's Avatar
Turbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond reputeTurbochris has a reputation beyond repute
Used pavers on mine......came out great
Chris
Old Jul 21, 2007 | 06:20 AM
Mussel Kar's Avatar
Mussel Kar is a jewel in the roughMussel Kar is a jewel in the roughMussel Kar is a jewel in the rough
I used Kleeman to decorate my driveway. Wifey got a bit upset.
We looked into stamped concrete but we have a huge driveway. I also need to plow in the winter and felt good old asphalt would be good enough. I'm not worried about the stripes because this is only the binder coat. Top coat will be done after the heavy equipment is done.
Old Jul 21, 2007 | 05:08 PM
gusmiami's Avatar
gusmiami is infamous around these parts
Originally Posted by NYSpeedRacer84
Not exactly a garage question, but close enough....I'm thinking about re doing my driveway and was considering to lay down tiles rather than straight cement or a mix of both. Do you guys have any recommendations?
I did Old Chicago Brick at my house and I love it. It's installed on sand, so water drains RIGHT thru it after you wash the car. Very low maintenance and looks great.
Old Jul 22, 2007 | 06:02 PM
24lemans's Avatar
24lemans is infamous around these parts
Can you use a jack on pavers? Or will it sink the pavers from the weight?
Chris
Old Jul 22, 2007 | 06:26 PM
gusmiami's Avatar
I've used a jack on mine with no problems
Old Jul 23, 2007 | 05:25 PM
Turbochris's Avatar
Not a problem as long as it's all installed correctly...my landscaper friend who did mine parks a 20,000lb dumptruck on his driveway every night and no problem after 5+ years.......and as far as a jack.....even if you cracked one...you just make sure they leave you 20 or 30 spares....you could remove it with a penknife and replace it in about 30 seconds......
Chris
Old Jul 23, 2007 | 05:44 PM
gusmiami's Avatar
Chris
Not to mention how easy it is to make changes or add to your driveway with the (brick) pavers.
Old Jul 24, 2007 | 12:24 AM
24lemans's Avatar
Good to know. I've been ruling out pavers, but from your responses, it seems to be no problem. Thanks.
Old Jul 24, 2007 | 10:00 PM
D-UberCars's Avatar
D-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud of
Depends on where you live and weather. In the wet NW. replaced the pavers w/stamped concrete b/c weeds would grow through constantly, then they would get mossy. Don't believe you would have that issue in So. CA. then you could also install a weed barrier under the pavers too.
Old Jul 27, 2007 | 06:15 AM
gusmiami's Avatar
it's definitely wet here in Miami as well, but my gardener uses roundup to take care of whatever springs up.
Old Jul 30, 2007 | 09:16 PM
grahamtwatson's Avatar
grahamtwatson is infamous around these parts
If you go with stamped concrete, make sure they include some sand or grit in the sealing coat. If they seal it without this, it will be VERY slippery when wet.
Old Jul 31, 2007 | 06:12 AM
Michael W.'s Avatar
Michael W. is infamous around these partsMichael W. is infamous around these parts
Originally Posted by Cole_21
Why not do an overlay of stamped concrete?
It can be made to look like tiles.
My only issue with concrete, stamped or not, is that eventually you will get cracks in it, and I hate cracks. I went with pavers on my driveway because they don't crack and a single paver can be easily replaced if need be.
Here is a picture of my driveway with pavers....
Old Jul 31, 2007 | 06:14 AM
Michael W.'s Avatar
Why would you not install a weed barrier in the NW? With the underlayment you should not have any issues with weeds. If you have a moss problem, you should have that problem with a regular or stamped concrete driveway as well.
