JRZ Coilovers Available at Vivid Racing
Vivid Racing is the newest distributor and tech center for JRZ USA suspension systems. With our racing background and strong relationship with JRZ USA, we are able to provide you with the best setup for your driving needs on any Porsche car you own. 993, 996, 997 models and more.
We are doing a introductory offer. Right now our 2 specials are on the RS Street and the Double Adjustable kits. SO PLEASE PM ME OR EMAIL for pricing!
http://www.vividracing.com/catalog/i...cturers_id=327
JRZ's double adjustment coilover is the ultimate in handling for the track and aggressive street driving. The double-adjustable shock allows external adjustment of both rebound and compression. In addition to the same precise and accurate rebound adjustment mechanism in the single-adjustable, the double-adjustable shock has a remote reservoir with the compression adjuster and gas volume. This reservoir is connected to the shock with a Teflon-lined high-pressure hose and uses a 22mm piston rod. The double-adjustable allows you to refine the handling of your car by adjusting both the rebound on the shock rod and the compression blow-off valve in the remote reservoir.
The RS damper allows for external adjustment of both the rebound and compression functions of the damper. In addition to the same precise and accurate rebound adjustment as in the single adjustable race damper, the RS are double adjustable. The compression adjustment technology is the same as that of the race version. The RS does not utilize a separate canister. The RS has both the rebound and compression adjustments on the damper itself.
Jul 29, 2019 11:13 AM
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
