Is the GT2 Front Wheel Carrier (hub assembly) Interchangeable with the TT?
I have several questions:
Any help with this is greatly appreciated.
- Is the 2002 GT2 front wheel carrier (hub assembly) interchangeable with the TT? This is the cast aluminum (presumably) component that holds the wheel bearings, connects to the steering tie rod, strut and control arm.
- If it is interchangeable, are the three primary pick-up points (strut, control arm and steering tie rod) at a lower elevation than the TT?
- If they are interchangeable, are the pick-up points uniform connections? In other words, will the stock TT strut, control arm and steering tie rod bolt right up?
- Can anyone take a photo of this area of a GT2 from under the car??
Macfly,
My intent is not to swap from 4WD to 2WD. I am amidst a vast amount of information that leads me to believe lowering a 996TT has more negative effects than positive ones if all one does is install coilovers and screw them down. I will spare you the details but in essence, the ideal scenario would be to raise the axle as it penetrates the wheel carrier. This does all of the following:
If you lower the car (sustantially) without addressing these things, the car's handling will actually degrade.
To answer your specific question, the benefits of a 4WD to 2WD conversion would be savings in weight primarily. Not having direct knowledge of the exact configuration or makeup of the viscous coupling, I wouldn't know what the impact is with regard to power deliver over a long period of time (other than the typical disconnects done for dynoing). The PSM and power split F/R would be other issues that need to be addressed since the front drivetrain would be absent. Not much help, I know....
- Preserves the shock travel
- Preserves the steering tie rod angle
- Preserves the control arm angle
- Eliminates the possibility of bump steer
I am now curious as to why you'd want to lower it? The 996TT is generally said to be the best all round sports car in the world as it is. I would have thought a great set of tires, and a piggy bank for your 'next car fund' would be a better way to go. You'll have a hell of a job selling it if you do all that work to it, and you'll be waving goodbye to a bunch of $$ in the process.
There is a factory 20mm lowering kit for Turbo coupes. It includes 4 shock/spring assemblies and 2 motor mounts. You can always trust the factory kit to enhance without compromises.
I wasn't thinking straight.
Enemy
Nov 10, 2015 08:01 AM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
