Traqmate Coordinates
Old Oct 30, 2008 | 03:34 PM
NormanK's Avatar
NormanK is infamous around these parts
Does anyone have the coordinates for the Start/Finish at Daytona for Traqmate?
Old Nov 3, 2008 | 02:07 PM
RonCT's Avatar
RonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond reputeRonCT has a reputation beyond repute
If I can't find a start/stop, I just hit the button when it says "looking for start / stop". I've had issues before with even track-provided coordinates, so I just set it first time at a new track anyway...
Old Nov 3, 2008 | 04:05 PM
Adrift's Avatar
Who let the dogs out...
Adrift is infamous around these parts
I am a new GT3 buyer. How well does Traqmate work? Does it update position fast enough to give decently accurate times? How much do they cost? Good source to buy one? Does it require some external antennae?
Old Nov 3, 2008 | 04:41 PM
NormanK's Avatar
Works well.
For accuracy, it is the gold standard.
For the full system +/- 1,000. See Traqmate: http://www.traqmate.com/
Seems to be prix fix.
It does require an external antenna.
Hope this helps.
Old Nov 3, 2008 | 07:56 PM
AZ997TT's Avatar
AZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to behold
Originally Posted by NormanK
Works well.
Hope this helps.
I was able to have a tab fabbed that allowed me to attach the antenna to the rear roll bar inside the car, works great.
Old Nov 3, 2008 | 08:27 PM
toadinlaw's Avatar
toadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud of
Would you mind posting a pic of your installment? I am planning on a TM and would like to see how you guys are installing the hardware. Did you mount the display on the steering wheel column?
Old Nov 3, 2008 | 08:36 PM
Adrift's Avatar
And how do you get the track organizers to let you park on start/finish so you can calibrate? lol Is this going to become a new ritual at DE's?
Consider this a second request for a picture of the install, and a description of how well it works inside the car.
Old Nov 3, 2008 | 08:55 PM
blakt out's Avatar
blakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond reputeblakt out has a reputation beyond repute
My transponder thingy is actually outside my window beside the Sirius radio thingy.
Old Nov 4, 2008 | 06:00 AM
RonCT's Avatar
There have been dozens of threads here and at RennList showing installations (my own photos are included) as well as long discussions on operation, video integration, accuracy (3 sample rates so you can get extremely accurate), setting start / finish with a simple press of a button on your 1st warm-up lap, etc. Just try a search and all will be revealed.
Old Nov 6, 2008 | 02:18 PM
heavychevy's Avatar
Park?
No dude, just drive by. When you have everything setup all you have to do is press the big green button on the display unit as you pass the start finish. Sounds challenging, but is REALLY easy. You need to push it while on the driving line for the best results. Doing it in pit lane may mess up the data on some tracks so dont do that.
Mine has been accurate to the tee with AMB transponders give or take me missing the finish line by a few feet which can change the time a bit.
Old Nov 7, 2008 | 04:36 PM
AZ997TT's Avatar
Sorry, I have been traveling. I dont know how to post pictures, pm me your email address and i will email it to you.
Old Nov 7, 2008 | 04:37 PM
AZ997TT's Avatar
Adrift, see above post, happy to email it to you as well.
Old Nov 7, 2008 | 06:00 PM
RonCT's Avatar
As mentioned in my last reply - photos and more info than you would ever want to read has already been posted about TraqMate here and more so at RennList. Hate to repost it all again - if you just search on "Traqmate" in the Racing and Drivers Education forum, you'll see it all. Nonetheless, here are the photos again - these were of my 997S, but I use the same installation on my 997 GT3. Takes about 5 minutes to set up and when I remove it, there is zero sign of any equipment, wiring, etc. Been using this method for 2 years and it works wonderfully. Cost for installation items, about $2.50 for double sided velcro strip (long). Antenna goes out the passenger window and I tape down the wire on the "leading edge" side.
Old Nov 7, 2008 | 07:26 PM
OldGuy's Avatar
OldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond repute
Heavy Ideally you want a couple points on a GPS point in a row to get a good fix. Unless you have differential GPS which I dont know if Traqmate does. But it would be better GPS wise if you could get a couple seconds of GPS data on the same point.
Old Nov 8, 2008 | 09:48 AM
heavychevy's Avatar
I have no idea if it's differential or not, but it works with the driveby and I've never seen one person stop on the track during a session or parade laps to get the start/finish coordinates.
Nuke
Sep 8, 2015 09:09 AM
GSR Autosport
Aug 26, 2015 05:20 PM
TrackOne
Aug 20, 2015 12:56 PM
