A and C pillar trim removal
Old Dec 9, 2008 | 01:35 PM
mikymu's Avatar
mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !
I need to remove the A and C pillar to get access to the headliner. Does anyone know how to remove the pillar trims? Does it simply pop out?
Old Dec 12, 2008 | 11:45 PM
mikymu's Avatar
i figure out how to remove the headliner with help of the 997 service CD. i only need to remove the front portion but the principle remained the same. here are couple photos for reference
pop the A pillar trim off gently by pulling. you can remove the coat hanger on B pillar by prying it off from the bottom of the bracket then loosen the screw on top of the B pillar and pop the top of B pillar trim lose to ease removal of A pillar
lift the front of the A pillar trim and it's off
the alcantara headliner canvas has thin metal wire frame that hook on to the sides of the A and C pillar. just simply unhook from the plastic retainer
remove the sun visors and central courtesy light assembly and disconnect the wires
pop the front portion of the headliner lose by pulling it downward. it is held up by couple metal clips
disconnect the metal wires that run across the headliner by gently pulling down on the mid portion of the wire and carefully twist the ends of the metal wire from the plastic clips at each sides. careful not to break the plastic clips
now loosen the rest of the cross support wire frames and the roof is exposed. install is a simple reversal of removal
Old Dec 13, 2008 | 01:21 AM
03-turbo911's Avatar
Senior Member
Fantastic post! This could be useful for some down the line.
You got rep..
Old Dec 13, 2008 | 01:23 AM
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
What are you trying to do?
Old Dec 13, 2008 | 03:41 AM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
maybe he's puttin on some CF replacement for his sunroof to save weight like his m3
Old Dec 13, 2008 | 04:43 PM
mikymu's Avatar
lol .... there are not much weight to be saved but CF foam for the roof?
NC 996TT
Mar 23, 2023 06:19 AM
BLKMGK
Sep 19, 2015 03:51 PM
AM v12v
Sep 7, 2015 02:17 PM
Wildcat1212
Sep 7, 2015 11:31 AM
markj
Sep 6, 2015 09:08 AM
