RS front factory ride height
Old Dec 26, 2008 | 11:45 PM
mikymu's Avatar
mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !
while getting to know my RS, i notice the ride height of the front suspension (between the black plastic retention rings on the shock assembly shown below) is about 3/16" (4.7 mm) higher on the driver side. the rear shock assembly has identical height. is this a typical set up from factory to compensate for driver's weight? i have not corner balance my RS yet
my M3's front driver side ride height is about 2/16" higher compare with the other side after corner balance. it's pretty impressive if RS come this way from factory to account for a 180 - 200 lbs driver
Old Dec 27, 2008 | 12:59 AM
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
I'll remember to measure them the next time I take off my wheels. That's interesting.
Old Dec 27, 2008 | 11:31 AM
mikymu's Avatar
thanks Kevin. I guess this is something most people don't notice unless you try to corner balance the car
Old Dec 27, 2008 | 12:30 PM
///M Kevin's Avatar
And especially if it's in mm. Hey, are you going to the meet in January at the Berkeley Marina? Daytonaviolet and I might stop by and we want to check out your new ride.
Old Dec 27, 2008 | 08:47 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
I recommend to corner balance the rs mine was very bad from the factory now is super good after 3 corner balance secions.
Old Dec 28, 2008 | 12:21 AM
mikymu's Avatar
when is the meet? i may be taking the RS to Thunderhill Jan 18th with Trackmaster if i it does not rain ... and if i can get my track tires by then. let me know the date and i may be able to meet up with you guys
i am going to corner balance it myself soon. DIY is a great way to get to know your car. i just can't find a bathroom scale that go up to 1000 lbs at Walmart lol
Old Dec 28, 2008 | 11:31 AM
///M Kevin's Avatar
I believe it's on the 20th.
Old Dec 28, 2008 | 07:13 PM
luiscarlos's Avatar
I have my own Longacre scales and a Bendpac ramp also you will need Longacre scale levels,Longacre laser to align the scales etc.
So maybe it will be better if you go to a perf shop and pay for the corner balance.
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
Aug 19, 2015 06:35 PM
Nissan GTR
Aug 19, 2015 02:11 PM
