To PCCB or not!?
Old Apr 8, 2009 | 12:58 AM
ir_fuel's Avatar
ir_fuel is infamous around these parts
Originally Posted by ///M Kevin
How much weight do you save if you opt for ceramics?
How much weight do you save if you opt for the gym?
Old Apr 8, 2009 | 08:43 AM
Sloopy's Avatar
Sloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of light
About 10 Lbs per corner depending on which breaks you are substituting. This is a lot different than shedding body weight though because it is unsprung. Ever watch the young fit women run at the gym. You can still see the unsprung weight move around.
Old Apr 8, 2009 | 09:11 AM
porsche4ever's Avatar
porsche4ever has a spectacular aura aboutporsche4ever has a spectacular aura aboutporsche4ever has a spectacular aura about
My PCCB under heavy track use were horrible at second track day, problem is the rotors only have 1mm of real live and pads have half durability live (on work hours) than rotors aprox.
Now I upgrade mines whith this: http://www.systemst.com/ and now I can say "I have a real ceramic-carbon brackes"
Sorry for my english.
Old Apr 8, 2009 | 04:29 PM
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
I guess I was referring to the guys that order their 997 without PCCB.....just the steel Porsche rotors.
Old Apr 8, 2009 | 04:32 PM
///M Kevin's Avatar
That depends if I can hit the gym at least 3 times a week.
Old Apr 9, 2009 | 10:50 AM
Targa Tim's Avatar
Targa Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond reputeTarga Tim has a reputation beyond repute
I don't lose wt going to the gym, I gain muscle mass.
Old Apr 10, 2009 | 02:00 AM
-K1-'s Avatar
-K1- is infamous around these parts
I find PCCB brilliant. No dust, lower unsprung weight gives better ride and performance. Brake feel is much better, what is not to like? Probably wouldn't spec on a C2/4 but a no brainer on GT2/3 or Turbo although I did regret not putting on wife's Cayman PD1.
Old Apr 10, 2009 | 06:35 AM
Andrew M3/M5's Avatar
Andrew M3/M5 is infamous around these parts
and muscle weighs more than fat!
Old Apr 10, 2009 | 02:30 PM
ir_fuel's Avatar
You can run and cycle at the gym too.
Old Apr 10, 2009 | 04:36 PM
Alcyon's Avatar
Alcyon has a spectacular aura aboutAlcyon has a spectacular aura about
porsche4ever tienes un mp
Old Apr 11, 2009 | 06:22 AM
Newt's Avatar
Newt is infamous around these parts
And I just did that...PCCB on my Cayman S PD1...
http://picasaweb.google.com/MijnNewt/#
Old Apr 11, 2009 | 08:26 AM
ir_fuel's Avatar
Aren't brakepads for PCCB disks a lot more expensive too?
Old Apr 11, 2009 | 08:37 AM
umwolverine's Avatar
umwolverine is infamous around these partsumwolverine is infamous around these parts
I've heard the total replacement for PCCB pads and rotors is around $40,000.
Maybe an exaggeration - but I'd check it out. If you're not running a dedicated track car - and even if you are and have a limited budget, I'd stick with the stock brakes, and upgrade the fluid.
Old Apr 11, 2009 | 09:05 AM
Turbo4ever's Avatar
Turbo4ever is a jewel in the roughTurbo4ever is a jewel in the roughTurbo4ever is a jewel in the rough
I don't why you need to replace it IF you maintain it correctly.
If people too worry about replacement cost, then he/she should not drive a Porsche IMO.
Old Apr 11, 2009 | 10:42 AM
sws1's Avatar
sws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of light
Not even close. Pads (front and rear) are about $800 (or less). Rotors are about $13-15k (all around).
