To PCCB or not!?
Old Jul 29, 2009 | 09:53 PM
  #31
PorscheUSA's Avatar
PorscheUSA is infamous around these parts
Newbie question
Originally Posted by umwolverine
I've heard the total replacement for PCCB pads and rotors is around $40,000.
Maybe an exaggeration - but I'd check it out. If you're not running a dedicated track car - and even if you are and have a limited budget, I'd stick with the stock brakes, and upgrade the fluid.
If your Porsche comes with PCCB brakes, can you not replace both the ceramic rotors and PCCB pads with regular (steel) rotors and pads when they are worn out?
Are PCCB brakes incompatible with regular (steel) rotors and pads? What would be the cost to "down-grade" to Porsche stock brakes if you can't afford replacing PCCB rotors and pads?
Thanks.
Old Aug 2, 2009 | 04:28 AM
  #32
sws1's Avatar
sws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of lightsws1 is a glorious beacon of light
Yes - change the rotors and pads (keep the hats) and you can use yellow calipers with steel. People do it all the time. Prices range from $2500 to $5k depending on brake company (Coleman, Brembo, etc.)
Old Aug 2, 2009 | 04:51 AM
  #33
911TurboS2's Avatar
911TurboS2 has a spectacular aura about911TurboS2 has a spectacular aura about911TurboS2 has a spectacular aura about
You're all nuts
I have had PCCB's on GT3s and 997 Turbos, and they have nowhere near the stopping power of actual Brembo or AP racing steel brakes that are used in almost all racing series (except Formula One). Nobody that is seriously tracking their car is using these brakes, the replacement costs are too high.
The margin that Porsche makes on these brakes, and on replacements is over 90%. To say that if you have to worry about the $40K replacement costs on a set of these brakes if you are a Porsche owner doesn't make sense- that's about a third of the cost of the entire car. That is just a poor economic decision. But, if you use it like a 'garage queen', and sell or trade it after a few thousand miles, like many Porsche owners, then do it.
Old Aug 2, 2009 | 05:04 AM
  #34
drnano's Avatar
drnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to behold
I agree, although they do have various pad compounds available which can change the results, I have the 'porsche motorsport' pads fitted and ive found that my PCCBs arent nearly up the challenge on the track. And replacing just one disk is the same price of a brand new set of 4 GT3 cup car calipers and disks front and rear. Not worth it IMO.
Old Aug 2, 2009 | 05:32 PM
  #35
aus's Avatar
aus
aus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud ofaus has much to be proud of
What tires are you guys using if the rotors are 380mm? You'd have to use a 19" wheel and there aren't too many 19" track tires out there.
Old Aug 2, 2009 | 07:13 PM
  #36
fortyounce's Avatar
fortyounce is a glorious beacon of lightfortyounce is a glorious beacon of lightfortyounce is a glorious beacon of lightfortyounce is a glorious beacon of lightfortyounce is a glorious beacon of light
Originally Posted by 911TurboS2
You're all nuts
+1
I totally agree with you.
Old Aug 3, 2009 | 01:18 AM
  #37
Broker404's Avatar
Broker404 is infamous around these partsBroker404 is infamous around these parts
How could they possibly be 40k to replace? They cost a fraction of that to get them brand new on a new Porsche.
Old Aug 3, 2009 | 08:58 AM
  #38
fortyounce's Avatar
$40k isn't correct.
When you order them as a factory option, do you also receive the steels no. So the there's an offset. Just because a factory option is say $9k, that doesn't mean you can pay $9k afterwards and get the same package. Converting over to PCCB is almost twice as expensive as the factory option.
Old Aug 3, 2009 | 10:53 AM
  #39
YellowDragon's Avatar
YellowDragon is infamous around these parts
According to Suncoast, f&r PCCB rotor+pad set is around $16,881 parts only.
http://e-partssales.com/Merchant2/me...ode=997GT3PCCB
Old Aug 3, 2009 | 03:43 PM
  #40
Broker404's Avatar
Originally Posted by fortyounce
$40k isn't correct.
I was considering that too... even with just the upgrade, I figure they couldn't be more than 14-15k
Old Oct 30, 2009 | 03:53 PM
  #41
cdragos's Avatar
cdragos is infamous around these parts
Originally Posted by mdrums
set of PCCB rotors is $15,000!!!! yes this is not a type-o.
NO IT IS NOT 15,000$! It is around $5,500
Old Oct 31, 2009 | 04:33 AM
  #42
sws1's Avatar
A set (being defined as all those needed to complete the car) takes 4 rotors. And costs about $15k. If you want to define a set as the pair for the front, or the pair for the back, you're still at $7-8k
Let's see this magical place that sells sets of rotors for $5,500. I'll be first in line.
Old Oct 31, 2009 | 05:56 AM
  #43
cdragos's Avatar
I'm sorry , you are correct - I was looking at the wrong place for prices.
It was very late at night
I have PCCBs in my 997 turbo, I hope they will get cheaper by the time I will have to change them.
There is an alternative: bolt on steel rotors for about 5-6,000$ I think, I think they would work better even the original steel because the front diameter is bigger compared to the stock
longboarder
Oct 28, 2015 12:10 PM
Michael_s
Oct 7, 2015 11:34 PM
I-Man
Sep 17, 2015 05:31 AM
spooltime
Cayenne Turbo
Sep 12, 2015 12:05 PM
Nuke
Sep 8, 2015 09:09 AM
