Track Wheels
Old Aug 13, 2009 | 09:55 PM
speedyellow4's Avatar
speedyellow4 is infamous around these parts
Track Wheels
Can I get some suggestions for a good set of wheels to use only at the track. I would not like to spend much money if I can get some decent wheels rather cheap. I need them for my 996 GT3.
Old Aug 14, 2009 | 12:03 AM
FerrariTifosi's Avatar
FerrariTifosi is infamous around these parts
not spending a lot of money is subjective. I can suggest great wheels for a bunch of price ranges, what is your limit?
Old Aug 14, 2009 | 09:30 AM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
Cheap is relative, but you'll get your dollars worth at CCW (http://www.ccwheel.com).
Great track wheels.
Old Aug 14, 2009 | 01:15 PM
I am just wondering if there are good wheels that are less than the typical price range of BBS and HRE even though I am aware that those two are great brands.
Old Aug 14, 2009 | 01:24 PM
raiyu's Avatar
Contact CCW directly and you should be able to pick something up for half the price of BBS or HRE.
Old Aug 14, 2009 | 01:40 PM
I have been looking at CCW online and that is the price range I was looking for. I appreciate the suggestion. I would just rather spend my money on other things for the car than some super expensive "track" wheels. Thank you.
Old Aug 15, 2009 | 03:06 AM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
OZ not the lightest or the best but they are the lightest for the money you are paying. contact doman from tirerack for more info
Old Aug 17, 2009 | 12:51 PM
LTCJMRamos's Avatar
LTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud ofLTCJMRamos has much to be proud of
Great track wheels.
+1 on CCWs.
Old Aug 17, 2009 | 01:39 PM
Gus F's Avatar
Gus F is infamous around these parts
I now a lot of people that is very happy with ccw's they are strong, ligth weigth and decent looking. I just received a set of O.Z. alleggerita's (8.5-12' X 18) they are even ligther and also good looking (i didn't had the chance to check or install them since for the moment i'm out traveling abroad), i'll intend to try them this weekend at Sebring, will post some pictures and results.
Old Aug 17, 2009 | 01:52 PM
XPGT2's Avatar
XPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to beholdXPGT2 is a splendid one to behold
Track Wheels = CCW which are forged
O.Z. alleggerita = Cast wheels which are not optimal for the abuse from a race track.
Peter
Old Aug 17, 2009 | 02:13 PM
Gus F's Avatar
Peter
O.Z. sells the alleggerita as track wheels, they say they are manufactured using a new and special cast process. O.Z. has technology and a long tradition manufacturing race wheels. Price is very competitive $ 1778.00 for the set, almost the same as a set of tires!!
Old Aug 17, 2009 | 02:25 PM
WHEELSJ's Avatar
Platinum Sponsor
WHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond reputeWHEELSJ has a reputation beyond repute
how about some Forgelines?
Wheels Boutique
"Slangin Dubs strong since 1999"
1.866.519.4335 ext 2103
Web: www.wheelsboutique.com
Email: Jonathan@wheelsboutique.com
#1 HRE Dealer Worldwide / DPE Wheels / Vertini / Work Wheels / D2 Forged / TechArt / Novitec / Brabus / Carlsson / AC Schnitzer / Mansory / Kooks / Corsa / RENNTech / WALD / Milltek / Tubi / Champion Motorsports / AWE / RSS / BBS / Brembo / Hamman / Eisenmann / KW / H&R / Nitto / Pirelli / Michelin / Dunlop / Goodyear / Falken / Continental and tons more....
Old Aug 18, 2009 | 10:26 AM
XPGT2's Avatar
http://www.tirerack.com/wheels/tech/....jsp?techid=90
Read about Low Pressure casting vs Forged.
Not that there is anything wrong with cast wheels. Just for the track I want the strongest.
Peter
Old Aug 18, 2009 | 04:50 PM
Gus F's Avatar
Peter
I totally agree with you that Forged Wheels will be stronger than Cast Wheels, but this cast from OZ has some technology improvements over traditional low pressure casting, I hope it is not marketing BS, for the cost of the wheels (almost half the cost than lowest forged competitors) seems to me it is worth to try them. Below find what OZ says about their HLT wheels:
"HLT: otherwise called coating. This technique uses rollers to move the material along the channel of a low-pressure cast aluminium wheel so as to lengthen it and give it the desired shape. This technology makes the material coated on the channel very compact, enhancing its mechanical characteristics.
The HLT wheels are produced with HLT technology that improves performance, reduces consumptions and guarantees the necessary resistance to pass the strictest safety tests. The innovation and the excellence of the HLT production processes (high light technology) are the result of the company’s direct experience in F1 racing, which earned OZ unparalleled knowledge in this field.
The sensitive channel coating process and the new HLT technologies make it possible to obtain mechanical characteristics that are similar to those of a moulded wheel, increasing drastically resistance, with a consequent reduction of the weight of the wheel."
Old Aug 18, 2009 | 05:23 PM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
do you have more/better pics of this car?
