CGT clutch wear and life
Old Sep 2, 2009 | 07:09 PM
Auctung's Avatar
Auctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud ofAuctung has much to be proud of
I tried going through the search function with varying keywords and couldnt find the exact measurments I was looking for.
IIRC 31mm is new and 27-28mm is replacement time, correct??
Old Sep 2, 2009 | 08:41 PM
bbs993tt's Avatar
bbs993tt is infamous around these parts
Those are the numbers I've heard as well.
Old Sep 3, 2009 | 10:51 PM
SmoothCab's Avatar
SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !SmoothCab Is a GOD !
This is straight off the installation CD that comes with the Carrera GT. It will give you the information that you desire.. Kenny
Old Sep 4, 2009 | 12:52 AM
20C4S's Avatar
clutch life is very long if drive properly. i've seen the ceramic clutch worn out due to many hardcore launches. another type of wear is poorly driven that cause the ceramic clutch surface being polished. problem is u almost can't test drive this type of car so be careful.
Old Sep 4, 2009 | 07:20 PM
Auctung's Avatar
all I see is a lil red "x"
Old Sep 7, 2009 | 04:52 AM
freeman's Avatar
freeman is infamous around these parts
You should never launche your CGT,otherwise you would need new clutch very very soon.
Don't give any throttle input until the car starts to move.
Very simple rule to follow.
If you drive like this and get used to it,the clutch will last you a very long time even for heavy track use.
Old Sep 8, 2009 | 04:28 PM
SmoothCab's Avatar
Wow I can see it plain as day... Maybe the refresh button would assist in re-loading the drawing for you... Kenny
Hybrid
Jun 28, 2024 06:05 AM
jaehoppa
Oct 22, 2015 09:17 PM
oo7
Sep 10, 2015 08:08 AM
GSP
Sep 9, 2015 05:31 AM
pjb84
Sep 2, 2015 12:57 AM
