Carbon roof conversion questions
Old Sep 12, 2009 | 07:44 PM
OmahaGT's Avatar
OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !OmahaGT Is a GOD !
If replace the roof/sunroof with carbon on my 2007 GT3, can I convert to OE alcantara headliner, map light, etc. from the GT2 and GT3 RS(no sunroof)?
what is needed to finish the roof's interior with factory finishes?
Would this give the needed clearance to install factory RS roll bar with front extention?
Thanks!
Old Sep 13, 2009 | 06:47 PM
Slow4s's Avatar
Slow4s has a spectacular aura aboutSlow4s has a spectacular aura about
I would only go with GMG Racing since they are the best in the business.
Lots of info here:
https://www.6speedonline.com/forums/...version-2.html
-Alex
Old Sep 13, 2009 | 11:29 PM
AZ997TT's Avatar
AZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to behold
Did the conversion on my race car, did not do a headliner, but that should not be a problem.
Yes it should give you the clearance for a full or half cage.
Old Sep 14, 2009 | 09:38 AM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
what type of material do they use to bond it to the car?
Old Sep 14, 2009 | 11:45 AM
akshon's Avatar
akshon is infamous around these parts
yes you use the oem headliner from a non sunroof car about $1000
and then you need a new map light for a non sunroof.
They usually use some type of aircraft grade epoxy glue to install the roof and it will give you the same clearnace as an RS
Lowtush
Jan 25, 2022 10:48 AM
Jul 29, 2019 11:13 AM
orbelo
Aug 30, 2015 12:26 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
