is the CGT production # in the VIN?
Old Nov 30, 2004 | 05:47 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
if so, where? thanks
Old Nov 30, 2004 | 06:28 PM
W8MM's Avatar
Honored Member
W8MM is infamous around these parts
The last 4 or 5 digits of the VIN may provide some insight into the production sequence. The dash plaque number DOES NOT necessarily have anything to do with the production sequence. Some dash plaque numbers were "reserved" for customer requests and were not issued in sequence.
Old Nov 30, 2004 | 06:35 PM
Poursha's Avatar
Poursha is infamous around these parts
The last 4 digits of the vin are the production number--here's more info:
http://www.vehicleidentificationnumber.com/index.html
Old Nov 30, 2004 | 09:30 PM
ben, lj's Avatar
Senior Member
How on earth then is my CGT (built Sept 04) #109X if they are only building 1500 (with 2 full years of production left after mine)?
Old Nov 30, 2004 | 09:38 PM
Poursha's Avatar
Could be with a limited production car they use the first place of the last 4 digits as a place holder (so yours is number 9X for MY '05)?
My last 2 Carreras last 3 digits were 29X and 49X, and both were in the first month or 2 of the model year, which makes sense.
Old Nov 30, 2004 | 09:41 PM
ben, lj's Avatar
Senior Member
Sure hope so. #9X for MY '05 still seems a little strong since I don't think they're up to much more than 2/day and the factory was closed in August. '05s didn't start til they reopened.
Old Nov 30, 2004 | 09:46 PM
Poursha's Avatar
The bottom of this page talks about models with less than 500 produced per year:
http://www.vehicleidentificationnumb...r_content.html
Old Dec 1, 2004 | 08:00 AM
ben, lj's Avatar
Senior Member
thanks, so the numbers don't mean much.
Old Dec 1, 2004 | 09:14 AM
Poursha's Avatar
The way I read it, the bold part of the following (from the bottom of that page) indicates that the last 3 digits is the serial number, for models with less than 500 produced per year:
(3) The third through the eighth characters of the fourth section shall represent the number sequentially assigned by the manufacturer in the production process if the manufacturer produces 500 or more vehicles of its type annually. If the manufacturer produces less than 500 motor vehicles of its type annually, the third, fourth and fifth characters of the fourth section, combined with the three characters of the first section, shall uniquely identify the manufacturer, make and type of the motor vehicle and the sixth, seventh, and eighth characters of the fourth section shall represent the number sequentially assigned by the manufacturer in the production process.
Old Dec 1, 2004 | 11:21 AM
fuse's Avatar
fuse is infamous around these parts
ben, lj- Did you order your CGT with 22 pages of option list or the original 5 page $0 option list? There are some nice options available now...but are very pricey.
CoreyC2S
Nov 18, 2017 12:13 PM
blrx7r1
Cayenne Turbo
Sep 11, 2017 08:53 AM
turbotuner20v
Sep 11, 2015 12:02 PM
away
Sep 4, 2015 12:30 PM
pwdrhound
Aug 20, 2015 05:54 AM
