Redline? is...
Old May 5, 2010 | 05:03 PM
DD GT3 RD's Avatar
DD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud of
Redline? is...
so i have a 2010 gt3 and curious about redline.
Redline on the dash indicates appx 8200 rpm...but i have read on internet/mags that its 8250, 8400, and 8500.
whats the deal?
Old May 5, 2010 | 07:38 PM
DD GT3 RD's Avatar
Old May 5, 2010 | 08:54 PM
sharkster's Avatar
8500 on your car. 8400 on mk1's and 8800 on 3.9's
Old May 5, 2010 | 11:25 PM
DD GT3 RD's Avatar
8800 has got to be amazing.
the am i correct that on the 2010 gt3 on the rpm gauge it appears as redline is 8200rpm...so its all good to go past?
Old May 6, 2010 | 10:33 AM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
You'll hit the rev limiter before anything bad happens so give it a shot past 8200 and if you hear it bounce off the rev limiter at that point then you'll know where it stops.
Old May 6, 2010 | 10:45 AM
DD GT3 RD's Avatar
my mistake..was counting each mark a 100rpm instead of 200. retarded. Finally found this:
Engine data
Type M 97/77
Horizontally opposed engine,
liquid cooled
Number of cylinders 6
Bore 4.04 in./102.7 mm
Stroke 3.01 in./76.4 mm
Cubic capacity 231.6 cu. in./3797 cm3
Net-horsepower 435 hp/320 kW
at crankshaft speed 7600 rpm
Net torque 317 ft. lb./430 Nm
at crankshaft speed 6250 rpm
Engine oil consumption up to 1.5 liters/1000 km
(1.6 quarts/622 miles)
Maximum permitted engine speed 8500 rpm
Engine control Stationary high-voltage distribution, sequential injection,
cylinder-selective knock-control, stereo oxygen sensor closed-loop control, diagnostic system,
4 overhead camshafts, Porsche VarioCam, hydraulic valve clearance compensation
Old May 6, 2010 | 11:31 AM
sharkster's Avatar
It's not bad:P
http://www.youtube.com/watch?v=XzeLcvgOVzQ
And not sure you're reading it right, it is 8500
Old May 6, 2010 | 11:38 AM
DD GT3 RD's Avatar
yep, i was reading it incorrectly. Amazing video
Old May 6, 2010 | 11:46 AM
sharkster's Avatar
Good! Make sure you use every one of those 8500rpm's
007 Vantage
Oct 8, 2015 08:35 PM
Oct 2, 2015 02:23 PM
panas001
Sep 27, 2015 02:51 PM
