? Torque steer - help
Old Feb 7, 2011 | 03:55 PM
pnixon's Avatar
pnixon is infamous around these parts
Looking at a lightly driven (based on rev report) .2GT3 with 5k miles. For sale at dealership. Price negotiated and agreed upon by me and the dealership pending inspection. Under heavy acceleration the car seems to push to the right and then back to the left immediately after letting off the gas. Again, only under heavy acceleration. I previous GT3RSR mechanic recommended getting the toe adjusted. It was sent into the service dept and suspension worked on (not sure what was done). I have not driven it since then but had it inspected by an independent shop. He also noticed the same thing but now only in first gear. Best I can describe would be the equivalent feeling of torque steer in a front wheel drive. Any recommendations as to where to go from here? (I have not driven it again since it was worked on in service)
Old Feb 7, 2011 | 05:10 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Before giving advice, it would be really good to know the existing alignment settings.
Old Feb 8, 2011 | 08:19 AM
KYROCKS's Avatar
KYROCKS is infamous around these parts
Ask them to swap the rear tires to other side. If it pulls in the opposite direction, you'll need to change both rear tires. This is what happened to me in my C4S. These cars are very sensitive to rear tire asymmetries. Other GT3 RS people have said the same thing. Also make sure a proper Porsche spec alignment is performed. Keep us posted.
Old Feb 8, 2011 | 02:59 PM
axhoaxho's Avatar
axhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud ofaxhoaxho has much to be proud of
Don't just swap the tires on the GT3 from left to right. Nowadays these tires - like the Corsa System on my GT3 - are directional. Swapping left and right will not yield desirable result to aid troubeshooting in this case.
Like folks say, the GT3/RS are very sensitive to alignment settings. Even when my car was brand new from the boat, the alignment was settled & off after 1,000 miles of break-in period (one front tire had out-of-spec toe angle.) I brought it back to my dealer and they readjusted it for free.
Try to ask your dealer to put the car on the alignment computer, and see what does the printout tell us.
Regards,
Old Feb 8, 2011 | 04:00 PM
KYROCKS's Avatar
Agree with axhoaxho with respect to directional tires. Only swap if non directional. These cars are sensitive to tires and to alignment.
Old Feb 9, 2011 | 06:40 PM
Harold's Avatar
Harold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud ofHarold has much to be proud of
Worn diff?
Old Feb 9, 2011 | 07:15 PM
DD GT3 RD's Avatar
DD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud of
before you purchase check out my ride! 2010 Meteor Grey w/ 5300 miles.
Old Feb 9, 2011 | 07:42 PM
KYROCKS's Avatar
^^^Agree. Check out his ride. Great price.
Old Feb 10, 2011 | 09:03 PM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
alignment is your problem.
it's rare to have bad tires do that, though it could happen.
you cannot have torque steer with a rear engine rear drive cars.
PV=nRT.
Sep 9, 2022 06:06 PM
jaehoppa
Oct 22, 2015 09:17 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
digitalzombie
Sep 9, 2015 04:03 PM
zuman
Sep 3, 2015 08:27 AM
