Rear clunk noise
Old Mar 29, 2005 | 11:48 AM
karlgt3's Avatar
karlgt3 is infamous around these parts
Question Rear clunk noise
My Gt3 has developed a rear clunk when I go over bumps at slower speeds. It sounds like the front clunking noise that I had that ended up being a loose swaybar. Where do I look and what tool(s) do I need!
Thank you
Karl
Old Mar 29, 2005 | 05:35 PM
retsel75's Avatar
retsel75 is infamous around these parts
GT-3 Clunk Sound
The drop links on the GT-3 sway bars need periodic tightening. It is very common. Most likely it is the bolt at the lower end that attaches to the wheel hub. Not a difficult job if you have a lft, otherwise it may require you taking off the wheel. You can also get a "clunk" if you go over a sharp driveway and one wheel gets lifted off the ground. The coil spring gets moved off it's mount and when it reseats you get a "twanging"sound.
Old Mar 30, 2005 | 04:56 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
I had the same issue when the vehicle got lowered it was the drop links..... The installers didn't figure that out after two visits, I did after about 10 minutes under the vehicle.....
-Eli
tzeseong
Aug 17, 2024 11:08 AM
Marcos AMV8
Dec 18, 2015 06:03 AM
docboy
Sep 6, 2015 06:57 AM
New991S
Aug 31, 2015 05:22 PM
Zero911
Aug 24, 2015 06:51 PM
