Schroth Harness
Old Apr 16, 2011 | 12:17 PM
Cajundaddy's Avatar
Cajundaddy is infamous around these parts
Google "spinal compression racing harness" for more info on the associated risks vs benefits. Or contact Schroth directly and ask them for recommendations. Again, ultimately you must decide which system is best suited for your driving. Having been in a triple rollover I can tell you that the 3 point belts worked as designed and I was able to grab the bottom of the steering wheel and duck down as the roof crushed in. It was an ugly wreck and I walked away without a scratch.
Below is an example of a common street car installation that does not meet Schroth requirements for a restraint system and would not pass tech at any of our events on the west coast.
http://p-car.com/diy/harness/harness.htm
Have fun, be safe!
Old Apr 16, 2011 | 01:04 PM
shtfrbrains's Avatar
shtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud of
Have fun, be safe!
Thanks for the info. I was also in a nasty roll-over a few years ago on the highway, and the DOT restraint system worked as advertised, and allowed me to walk away. I am sure there is an awesome knowledge base in the race car world. As a matter of fact, aviation has benefitted from some of the advances that took place on the race track, and vice versa.
Where I work there is a substantial Research and Development department mainly for helicopter aviation. I am going to ask those guys about 5 point harnesses in aircraft versus vehicles. It just makes me wonder, that's all. Keep in mind there are no helmet restraint systems in helo's either.
Old Apr 16, 2011 | 10:43 PM
996flt6's Avatar
996flt6 is infamous around these parts
Dale Earnhardt Sr died of said with just wearing a 6 point wo a Hans. U know our heads weighs like a bowling ball. Neway it's your life- sometimes it's all fate if it happens. Mike
Old Apr 18, 2011 | 12:58 PM
Originally Posted by jakegt3
I also kept the factory seat belts when I installed my harness. On the street I use the factory belt + the lap belts of the harness (because I don't want the harness buckle dangling free). To keep the seat belt warning from going on when you use only the harness on the track, you can insert a dummy buckle piece into the factory seat belt receptacle. For example, see http://pkvista.com/TraqJunk/Index.html. You can get cheaper versions of the same type of thing on eBay (mostly from China).
LA Dismantlers is a good place to order the seat belt buckle inserts. I ordered mine today, and they said it is a fairly common request they get from folks setting up their Porsches for the track. They salvage them from Porsche seat belts that were activated in crashes, so the complete seat belt system is no longer usable. They are $25.
Old Apr 19, 2011 | 07:58 AM
obsessed's Avatar
obsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to beholdobsessed is a splendid one to behold
Good cheap source for a spare buckle to defeat selt belt warning when using harness at track is to buy a seat belt extender on ebay - they often are sold for as little as $6.99. Nearly always listed - measure the width of yours to order correct size - if I recall correctly it is 7/8". Just cut the extender belt off the buckle with a knife or scizzors. Sample listing http://cgi.ebay.com/ebaymotors/New-1...item3f02361fee
wrs
Nov 17, 2016 06:53 AM
Glasgo
Nov 30, 2015 02:37 PM
914rrr
Nov 15, 2015 11:29 AM
Compukidd
Sep 30, 2015 11:03 AM
TypeRx
Sep 28, 2015 08:24 PM
