harness use with sport adaptive seats?
Old Sep 26, 2011 | 12:30 PM
GT3 Chuck's Avatar
Administrator
on most new SA helmets the holes are already pre-drilled with a little rubber plug inserted...remove the insert and installing the nutwashers is a piece of cake
Old Sep 26, 2011 | 02:34 PM
greyhound's Avatar
greyhound is infamous around these partsgreyhound is infamous around these parts
Anyone have any leads on some lightly used gt2 seats? I understand Suncoast has them at a good price for new. Just a lot of money for seats. Thanks.
Old Sep 26, 2011 | 03:40 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Originally Posted by gstahl
I do not have personal experience, there seems to be some info here in the quick start guides (which are also a good read)....
HANS Quick-Start-Guides
Here is the paragraph about installing anchors, seems straight forward on the surface...
A. Gently pry helmet liner away from shell using blunt instrument (fig. 6) and insert the nutwasher inside the helmet against the shell using a wrench. Align with hole. Insert post through cap, spring and base and screw into nutwasher. Tighten until the point of the post faces rearward.
B. Use a 7/16” (11mm) wrench to hold the post anchor outside of the helmet in position and tighten from inside (fig. 7). Tighten 1⁄4 turn beyond snug. The flats and slot of the post anchor should be parallel with the ground and the point of the post should face the rear of the helmet.
Thanks Geoff. Not sure I like the idea of prying the shell from the liner, but as long as it has the ability for adjustment, I supposed that's all I need to know.
Old Sep 26, 2011 | 09:53 PM
SKXF430's Avatar
SKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud ofSKXF430 has much to be proud of
Here is a helpful video of installing the Hans posts.
http://www.youtube.com/watch?v=wZgun...layer_embedded
Old Sep 26, 2011 | 10:02 PM
bonehead's Avatar
Thanks for the vid, too! I assume it would be very difficult/impossible to score the inside of the shell with that piece as you're working into the drilled hole to the point where it would compromise integrity? Seems like that guy was really working that wrench and nutwasher with a good deal of force.
Old Oct 16, 2011 | 04:44 AM
Slow911TT68Tip's Avatar
Slow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really nice
I have a gt2 which will be completed in days. I researching the possibility of adding slots for harnesses.
The only items to consider for me would be:
1. Identifying a reputable custom car/upolstry shop.
2. Identifying exactly where the airbags are tucked within the seat (if the are).
3. There are many choices of harness holes including custom made (I have access to machinery that will cut anything, any shape).
4. For those with a mechanical mind................ the sleeves to be inserted in the holes are merely two tubes of the correct shape with flanges on both sides (front and back of the seat). One "tube" (preferably the one with the flange at the front of the seat would be slightly larger than the sleeve facing the opposite direction).
5. This is NOT rocket science. Caravaggio Corvette maufacturers or better defined as coverting std seats to those with harness holes.
6. If you are of the right height and weight there is no reason the harness holes could not be added.
These are custom seats (with harness holes) mfg by Caravaggio (the work is impecable):
Here are customs seats made from base seats showing harness holes made by Caravaggio:
http://i426.photobucket.com/albums/p...2/DSC05779.jpg
Old Oct 17, 2011 | 05:44 PM
greyhound's Avatar
Very interesting idea. The gt2 seats are six grand plus at last search. I love the comfort and adjustability of my stock sport adaptive seat. Any ideas of a manufacture for Porsche? I would worry about the airbag issue and any implications to insurance and/or warranty. Thanks.
Old Oct 19, 2011 | 07:16 PM
KYROCKS's Avatar
KYROCKS is infamous around these parts
I heard Isringhausen Porsche in Springfield, IL can get you the GT2 sport buckets for 10% less than Suncoast.
Old Aug 25, 2012 | 09:06 AM
matthewbounds's Avatar
matthewbounds is a jewel in the roughmatthewbounds is a jewel in the roughmatthewbounds is a jewel in the rough
WOW! Love this! Need a way to make this work on my seats.
Old Aug 25, 2012 | 09:26 AM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
Originally Posted by Trollinger
Not the best picture, but you get the idea. I think they turned out really well, add to the room, and are very comfy. You can sit in them all day and not get tired. With a 12v battery (or charger) the seatbacks recline as well.
Trollinger, I have these seats sitting in my office and this wold be a nice way to store and use them.
A few questions:
How did you attach to the base?
I would imagine that this setup is a little top heavy and can easily tip over. Can you elaborate?
Old Aug 31, 2012 | 12:38 AM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
I purchased a set of GT2 seats from Isringhausen a couple of years ago and at the time they had the best price. Nice people to work with.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Michael_s
Sep 11, 2015 08:03 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Konea420
Aug 25, 2015 09:44 AM
The Oss
Aug 24, 2015 08:19 PM
