.2 GT3 Front OEM Spoiler...
Old Mar 22, 2012 | 10:57 AM
QuickTurns's Avatar
QuickTurns is infamous around these parts
xxxx
Last edited by QuickTurns; Mar 22, 2012 at 11:12 PM. Reason: noone seems to know or care :-(
Old Mar 24, 2012 | 05:03 PM
Mister PINK's Avatar
Mister PINK is infamous around these parts
My fav post! ???
Old Mar 24, 2012 | 06:19 PM
QuickTurns's Avatar
I'm impressed! Somebody's favorite post . I "x'd" it out after a 100 views and no response. I thought I must have asked a really stupid question...My front lip spoiler came loose and I wanted to know how to reattach...
Old Mar 24, 2012 | 08:13 PM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
Don't worry. Crawl under the car and check it out. If it's the same as the .1's then it slips into place and has a few screws holding it in. It's pretty self explanatory once you look at it.
If you damaged it and want to know how to fix it to stay in place, well, you'll have to fabricate something, which should still be pretty simple.
Post up your fix if you do so.
Old Mar 24, 2012 | 08:53 PM
QuickTurns's Avatar
Hi "RAudiDriver"! You must have had an Audi at some time... I have an '01 allroad with 45k miles for my snow trips to the Sierra's but would love an umolested '01 S4 manual.
Anyway, the outer attachment screw on the right side of the lip spoiler is in crooked, loose and about to come out. I found that when I crawled underneath checking the car after a track day. The screw not only holds the spoiler but also the little vertical "slats/flaps' that the 997's have on each side (GT3 and otherwise). When I tried to fasten it it wouldn't bite and my question WAS (and still IS) whether there's a NUT PLATE behind the under body bumper panel and if so, how do you "realign" it with the body panel hole? If not, and the hole is "worn" then I guess it's time to "invent" a fix like you suggested. Since any GT3 or Carrera S driver has that same spoiler I thought when I first posted that someone must have faced my "attachment" dilemma before and maybe has found an easy fix since those little vertical slats get scraped all the time and put pressure on the spoiler attachment at the same time. The center and the left side of the spoiler are still firmly attached. I have a lift and still get scrapes on our bumpy California freeways on the way to the track...
Old Mar 24, 2012 | 09:21 PM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
Don't believe there is a nut behind it. If its the same screw I think youre talking about its just a plastic one correct? I actually took mine out when I put my cup lip on and it stuck in there fine. Now my .2 cup lip likes to pop out
Old Mar 24, 2012 | 09:40 PM
If I can recall correctly, there might be one of those metal body panel nuts wrapped around one of the plastic pieces. I can't be for sure as it was a few months ago that I was tinkering in there. If there isn't, maybe you can use one to fix the issue.
On another note, yes I still have my Audi. It's a 2008 RS 4, Ohlins, HRE's, Euro Flat Bottom Steering wheel, H&R Sways, Short Shifter, Milltek Exhaust and a few other small goodies that I forget.
Old Mar 25, 2012 | 10:48 AM
QuickTurns's Avatar
Beautiful color and very nice-looking wheels! Keep it! Like I probably will my GT3. The new "stuff" coming out of Europe is more "robotic" than ever, a nanny here and a nanny there. I read in the latest "Automobile" mag that the 991 GT3 is to arrive in late 2014 as a 2015 model with 430HP. If that's true -and even if it's faster than our current version- why would I spend by that time probably $70K to upgrade for 5HP less? Like they say, there's no substitute for power (and for good non-electric steering). I would probably only consider around 500HP as a justification to upgrade.
Enemy
Nov 10, 2015 08:01 AM
JayJayJohn
Sep 17, 2015 05:09 PM
TrackOne
Aug 20, 2015 12:56 PM
pwdrhound
Aug 20, 2015 05:54 AM
