Clutch Bleeding
Old Jul 27, 2012 | 01:52 PM
BoxsterMac's Avatar
BoxsterMac is infamous around these parts
Clutch Bleeding
Last night I did my first brake bleed on my new (to me) 997.1 GT3. I also wanted to bleed the clutch lines. I read up on how to do this, but once I located the bleed valve on the clutch slave cylinder I was not able to reach it. My are could not get past the other lines in order to reach, much less open, the bleed valve. Has anyone done this and how did they get to the bleed valve? Thanks for any help!
Old Jul 28, 2012 | 08:02 AM
911S4's Avatar
911S4 is infamous around these parts
If you reach over the gearbox on the right side - passenger side you can access the clutch slave cylinder. The bleeder valve is elongated and I believe its an 8 mm. Using the Motive Power Bleeder to pressurize the master cylinder reservoir is the way to go. Just take your time and feel around over the top of the gearbox.
Old Jul 31, 2012 | 12:55 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
I'll give you my philosophical answer, if you have to ask, with something as important as a clutch, then take it to a pro.
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
Blue Chip
Sep 10, 2015 07:07 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
