Torque Solutions Urethane Transmission mount review
Old Jan 20, 2013 | 01:37 AM
ur20v's Avatar
ur20v is a name known to allur20v is a name known to allur20v is a name known to allur20v is a name known to allur20v is a name known to allur20v is a name known to all
I fitted torque solutions transmission mount a month or so ago, did it on 2 axle stands. Undertrays were fiddly doing it this way. about 1.5hrs start to finish.
Result:
*rear of car now very stable when changing direction and car settles straight away.
*Very positive to throttle inputs
*almost eliminated kangarooing when pulling away at slow/walking speeds
*very positive rifle like action to gear change and now 100% cured any 2-3 shift issues- now a perfect gear change!!:thumbup: Note: I already run cup cables, RSS engine mounts and Numeric Racings shifter.
*Some drone from engine- engine much loader in cabin by ~20%
Jay
Old Jan 22, 2013 | 06:57 PM
EUGENE-Taiwan's Avatar
EUGENE-Taiwan has a spectacular aura aboutEUGENE-Taiwan has a spectacular aura about
Do you have a LT. Flywheel set up?
Because from what I know these mounts if paired with a LT. Flywheels set up the noise is more noticeable
Old Jan 22, 2013 | 09:10 PM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
if u fear noise, dont do any these mounts.
Old Jan 23, 2013 | 01:06 AM
I have the solid mounts on my 964 and its really loud especially with the RS flywheel.
I guess on my 964 there is no interior which makes it loud as well
Old Jan 23, 2013 | 03:33 AM
ur20v's Avatar
No LWFW... yet!
Old Jan 24, 2013 | 07:36 PM
HarmonyJim's Avatar
HarmonyJim is infamous around these parts
Mooty, are you aware of the new TS inserts in both 75A and 95A densities? Are these both problematic for noise as you state above?
Old Jan 24, 2013 | 09:42 PM
mooty's Avatar
no, either is fine.
i am talking about true solid mounts, metal on metal.
these hard urethane is great.
Old Jan 24, 2013 | 10:24 PM
HarmonyJim's Avatar
Thanks mooty.
Jul 29, 2019 11:13 AM
CoreyC2S
Nov 18, 2017 12:13 PM
HotRod
Sep 10, 2015 07:17 PM
hacellular
Aug 31, 2015 08:34 AM
orbelo
Aug 30, 2015 12:26 PM
