Grill Screens
I made my own. This process is so easy, you just mock up the grill in cardboard and then cut a piece of high density fiberboard to these measurements. Bend your grill material around the wood pattern. I then took the pieces to the power coater and had them sprayed in flat black. Turned out fantastic...
Yes the bumper must come off and there are some DIYs available to show you how to do it. I used machine screws to attache the screen to the bumper in a way that is not detectable. The screen material was sourced locally and it is rather expensive but I made two sets just in case one was damaged. I have enough material left over to make at least one more set. For my car the center section must also be done because airflows through unlike most 911's which has a dummy panel with no airflow.
yes, the bumper was removed for the install on mine. I think that self-tapping screws would be a good backup along with the adhesive (as I've already found out there isn't a backup for an adhesive failure). My bumper has to come off for the repair now anyways, so I'm going to see if the screws can be added for backup and longevity.
adnanm3
Oct 25, 2016 08:38 AM
