Questions about buying 996 GT3 MK2
Old Aug 28, 2013 | 02:44 PM
See-Fu's Avatar
See-Fu is infamous around these parts
I've been searching for a 996 GT3 and I'm curious what are the major areas of the car I should inspect before purchasing. Also what were the major problems of the 996 GT3?
Old Aug 28, 2013 | 03:21 PM
AP328's Avatar
AP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to beholdAP328 is a splendid one to behold
I think this has been pretty well covered in this forum, but a short summary would be LSD (Guard Transmission - excellent service and product), pinning of coolant hoses as these tend to be problematic and a detailed PPI by marque specialist.
Old Aug 28, 2013 | 03:32 PM
See-Fu's Avatar
what keywords should I use for my search? I wasn't able to find any specific thread
Old Aug 28, 2013 | 11:57 PM
AP328's Avatar
If you are having trouble here, you might try Rennlist as they have a specific 996 GT3 section.
Old Aug 29, 2013 | 12:01 AM
AP328's Avatar
I just tried one search using 996 GT3 PPI and got some hits. Although I did mention a PPI, it is worth mentioning explicitly that you will want to check over revs. Any reputable service provider should do that even if you don't ask, but no sense in assuming.
Old Aug 29, 2013 | 07:57 AM
gman3280's Avatar
gman3280 is infamous around these parts
+1 Pretty much covers it. I went through the same thing purchasing my 6Gt3
Old Aug 30, 2013 | 08:12 AM
Trollinger's Avatar
Trollinger is infamous around these parts
Excellence Mag did a great 2-3 part series on PPI if you can get you hands on it. Great depth on what to check and how much to pay. Articles were sometime this year.
Old Sep 4, 2013 | 08:44 PM
rbahr's Avatar
rbahr is infamous around these parts
Just went through this:
Get a PPI by someone YOU trust, you are interested in the following:
  • Coolant lines - fittings are epoxied and come loose (lots of threads on this), should be welded or pinned
  • LSD - wear out quickly - has it been serviced?...
  • Accidents - a lot of these have been wrinkled a bit esp if they are tracked...
  • Type 2 Overrevs - these can be really bad - but then the damage that they can cause (bent valves) can be fixed)
  • I like Leakdown - needs to be done properly
  • Compression
  • Get repair records
  • Understand the history of the car - was it raced, was it tracked - none of these are necessarily bad - just important to know
  • What mods were made to the car
HTH
Ray
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
