new GT3 wide body???
Old Nov 12, 2013 | 10:20 AM
bsavino's Avatar
bsavino is a jewel in the roughbsavino is a jewel in the roughbsavino is a jewel in the roughbsavino is a jewel in the rough
i was looking on the porsche website and on the 'standard equipment list" under the body section it states thats: 'two-seater coupe' with wide 911 Turbo body'...is this correct or is this a typo??
Old Nov 12, 2013 | 10:42 AM
speedsterr's Avatar
speedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud of
It is correct I believe. The GT3 uses the rear turbo wide body for the rear panels.
Old Nov 12, 2013 | 11:42 AM
bsavino's Avatar
so new gt3 is a wide body??old one is not, am I correct??
Old Nov 12, 2013 | 12:49 PM
reidry's Avatar
reidry is infamous around these parts
Here are the widths of each 991 sub-model from Porsche technical specifictaions, width with mirrors folded.
C2S 71.18 inches
C4S 72.91 inches
GT3 72.91 inches
T 74 inches
TS 74 inches
T= Turbo, TS = Turbo S
So the GT3 uses the C4S widebody.
Internet suspicion says GT3RS will use 74 inch wide Turbo body.
Previous generation GT3s used the C2S narrowbody.
Ryan
Old Nov 12, 2013 | 02:51 PM
SpeeddemonC2's Avatar
SpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant futureSpeeddemonC2 has a brilliant future
C2S 71.18 inches
C4S 72.91 inches
GT3 72.91 inches
T 74 inches
TS 74 inches
Ryan
I agree with everything listed above by reidry from what I have read so far.
Old Nov 12, 2013 | 04:13 PM
empunker's Avatar
empunker is a glorious beacon of lightempunker is a glorious beacon of lightempunker is a glorious beacon of lightempunker is a glorious beacon of lightempunker is a glorious beacon of light
so new gt3 is a wide body?? old one is not, am I correct??
I know the 996 GT3 was a narrow body like the 996 Carrera.
I believe the 997 GT3 was a wide body, the same as the 997 C4/C4S. And the 997 GT3 RS/4.0 was the same as the 997 Turbo.
The 991 will probably follow this same pattern.
Old Nov 12, 2013 | 04:31 PM
reidry's Avatar
Not exactly...
997 C2 - 1,808 mm (71.18 in)
997 C2S - 1,808 mm (71.18 in)
997 C4 - 1,852 mm (72.91 in)
997 C4S - 1,852 mm (72.91 in)
997 GT3 - 1,808 mm (71.18 in)
997 GT3RS - 1,852 mm (72.91 in)
997 T - 1,852 mm (72.91 in)
997 TS - 1,852 mm (72.91 in)
997 RS4.0 - 72.9 in
Ryan
Old Nov 12, 2013 | 05:45 PM
speedsterr's Avatar
C2S 71.18 inches
C4S 72.91 inches
GT3 72.91 inches
T 74 inches
TS 74 inches
Ryan
Interesting then the video review I watched of the GT3 got the info wrong saying it was the turbo body.
Old Nov 12, 2013 | 07:24 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Not exactly...
997 RS4.0 - 72.9 in
Ryan
This can't be correct. The S versions of both cars are wider than the standard. The C2S & C4S have the same body as the turbo in the 997 series.
I think the Porsche site still says the Gt3 has the turbo body width, because it did at the time since the 991 turbo was released later. So, the new GT3 has the same width as the old 997 turbo.
Old Nov 12, 2013 | 07:37 PM
amerlemans's Avatar
amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !amerlemans Is a GOD !
You are dead wrong. Reidry is 100% accurate.
The S has no bearing on widebody at all. The 997 widebodies were the C4 and C4S, the Turbo variants and the 997 GT3 RS(and RSR) and GT2
997, 997S and 997 GT3 were all narrow body 911's.
Old Nov 12, 2013 | 08:54 PM
reidry's Avatar
Here's the link to the 997 brochure.
http://www.google.com/url?sa=t&rct=j...sFBKWkTtQgpkdg
Ryan
Old Nov 12, 2013 | 09:30 PM
Nikolas's Avatar
What do ya know! I always thought the S versions were wide body.
Was it that way for the 996 also? I thought I remember a difference back then between the C4 & C4s. I guess I incorrectly assumed that carried over.
Old Nov 13, 2013 | 10:49 AM
You are right about the S versions being wider in both the 993 and 996 iterations. In both those iterations the C4S used the Turbo body but with the same engine as the non-S versions. With the 997, S versions marked a different engine and HP instead of a different body. Once again REIDRY is correct with the stats!
Old Nov 13, 2013 | 01:33 PM
Nikolas's Avatar
Whew, glad I was correct about something.
Thanks for the clarification Reirdry and SpeeddemonC2!
Old Nov 13, 2013 | 02:15 PM
HotHonda's Avatar
HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !HotHonda Is a GOD !
My understanding in the 997:
The C2, C2S, GT3 are all narrow bodies
The C4, C4S, Targa 4, Targa 4S, TT, GT3RS, and GT2 are all wide body
manny5
Feb 9, 2016 11:54 AM
TTS
Nov 5, 2015 09:04 PM
AUDIRS6
11
Oct 8, 2015 12:21 PM
Mar48
Aug 24, 2015 01:13 PM
