MotorSports by Reeves Guards Red Porsche 991.2 GT3 RS BBi Roll Bar & Harness Install
Old Apr 19, 2018 | 04:15 PM
BBiAutosport's Avatar
BBiAutosport is infamous around these parts
Attachment 1
MotorSports by Reeves Guards Red Porsche 991.2 GT3 RS BBi StreetCup Roll Bar & Harness Install
Another 2018 Porsche 991.2 GT3s getting delivered with BBi Autosport treatment. Part of the Porsche of Tampa dealership family, Motorsports by Reeves installed our StreetCup Roll Bar powder coated in matching Guards Red, Sub-Strap Brackets, and Schroth Racing harnesses for the driver and passenger to be properly secured.
BBi Autosport Porsche 991 GT3 StreetCup II Bolt-In Roll Bar
To increase protection, our bar features a 2 piece design and 4130 chrome moly steel tubing (1.625" x 0.095) with excellent strength to weight ratio. With our sensible design approach, the 2 piece design mounts to frame structure, utilizing factory bolts, to provide strongest mounting points and maximum protection. For superior strength and rigidity, the bar utilizes "X" braces on both front and rear sections and each joint has been meticulously TIG welded by hand.
Features
  • 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
  • TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
  • Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock seats or any aftermarket seats on the market
  • Allows full seat travel to accommodate taller drivers
  • Can be used with stock seatbelts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
  • Made in USA
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
If you have the optional Sport Bucket seats and planning to install 6-point race harnesses, then you will need this bracket. This bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
About Motorsports By Reeves
MotorSports by Reeves is a division of Reeves Import Motorcars which owns and operates Porsche of Tampa dealership. For 16 years MotorSports by Reeves have been helping customers personalize, accessorize, and customize their vehicles. Established in 1997, MotorSports by Reeves have provided the Tampa Bay area with top quality styling and performance upgrades. Whether OEM or aftermarket, MotorSports by Reeves delivers superb products, and backs them up with an outstanding warranty.
Address: 11333 N Florida Ave, Tampa, FL 33612
Phone: (813) 375-3520
Website: http://www.reevesimportmotorcars.com...orts-by-reeves
- Jerry@BBiAutosport.com
