PCCB Question
Old Apr 29, 2006 | 02:05 AM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
PCCB Question
I have heard that you can swap out steel rotors for the ceramics if you choose. Is this accurate? No probs with the calipers working with steel v. the OEM ceramic??? Are they standard calipers for the GT3 and just painted yellow or are the calipers different as well? Thanks.
Old Apr 29, 2006 | 02:54 AM
Z06's Avatar
Z06
Z06 is infamous around these parts
Yes for the front, options for the rear...
I have the AP real race non floating front rotors.360mm and the rear is still PCCB, as far as I am concerned it's the only choice.
They have an AP kit for the rear conversion, PCCB rear is 350mm rotor and the steel is 330mm.
Old Apr 29, 2006 | 07:00 AM
NJ-GT's Avatar
NJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud ofNJ-GT has much to be proud of
The 997 GT3 Cup Steel rotor is a direct swap for the rear 996 GT3 PCCB.
Front calipers are the same, rear ones have a 10mm offset on the PCCB cars
Old Apr 29, 2006 | 03:41 PM
03-turbo911's Avatar
Senior Member
That's very good news NJ-GT.
Old May 2, 2006 | 10:12 PM
OldGuy's Avatar
OldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond repute
THe other thing you can do is get the right pads for your PCCBs and
they last ALOT longer. 4 curves on this board did it and tracked it till the cows came home or till he got his Cup car. Now his wife tracks it.
this is gen one PCCB with I think the CGT front pads and some pagid yellows for the back.
Here are the part # for correct PCCB use
front 98035193900
rear 996 352 947 03
I got these from 4 curves himself
WaltB
Mar 27, 2026 09:25 AM
twnj
Apr 29, 2016 05:18 AM
J9277655
Dec 28, 2015 11:01 PM
Small Shrimp
Sep 1, 2015 10:51 AM
turbosonoma
Aug 19, 2015 02:05 PM
