New GT3, 2 questions
Old May 10, 2007 | 11:53 PM
drqiman's Avatar
drqiman is infamous around these parts
My GT3 is one week old. I have about 1100 miles on it. It is beyond my expecations in quality and performance. I will submit pictures at a later time because this is my first post and I have some urgent questions.
First, the good news is tha TPMS did it's job and alerted me to a flat. The bad news is that I will now have to repalce the rear tire with a new one at just 1100 miles. My question is: Do I have to replace both rear tires since there is already wear on the good tire and the new tire will be of larger diameter and have no wear. I am concerned that not doing so could cause handling problems due to differences in grip and put excessive strain on the limited slip differential due to different tire diameters.
The other question is regarding oil. When I checked the level today, it showed no bars. I checked it several times with the same result. It was low.
I added .5 quart of oil and now it reads one bar over max level. I am perplexed by the discrepancy because according to the manual, the difference between the upper and lower levels is more than one quart and I just added .4 quart and now it reads over the max line. Is the computer reading accurate?
I assume that the oil wasn't overfilled from the factory and that during the initial 1100 mi. the car should have consumed some oil so how could addding .4 qt of oil bring the level over the max. In the worse case scenario, I am only overfilled by .4 quart. Can overfilling by .4 quart harm the engine.
Thanks,
Martin
Old May 10, 2007 | 11:56 PM
LABrit's Avatar
LABrit is a glorious beacon of lightLABrit is a glorious beacon of lightLABrit is a glorious beacon of lightLABrit is a glorious beacon of lightLABrit is a glorious beacon of light
I have no answers to either question, but your ? regarding the tires is actually quite interesting and i am looking fwd to reading the responses on it.
Congrats on the purchase, hopefully someone will enlighten you,
Josh.
Old May 11, 2007 | 12:06 AM
notquitefob's Avatar
notquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud ofnotquitefob has much to be proud of
porsche's official recommendation is that as long as tread depth between the two sides are within 30%, it will be fine.
and congrats on the new purchase.
Old May 11, 2007 | 01:17 AM
raffi's Avatar
raffi is infamous around these parts
are you sure all the readings were on level ground?
Old May 11, 2007 | 02:44 AM
chris5150's Avatar
chris5150 is infamous around these parts
I dont understand how it can read over the max line..I thought all bars filled up was max, how do u know when its over?. My GT3 showed down to one bar at 500 miles so I put a quart in ( a litre ) and it has shown full bars on the oil guage since..wonder if I overfilled then!. All my readings have been done after driving and on flat ground. Once the guage showed 2 bars under max, took it again 1 minute later in exactly the same place and it showed full, and has done ever since. Me thinks these electronic guages are not that accurate.
Old May 11, 2007 | 05:38 AM
pilone's Avatar
pilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nicepilone is just really nice
Well...One thing I can say to you it to check the oil level only when the car is cold...otherwise the oil will still going through the engine and won't be precise to check.
Well you only had 1100 miles on the car but I don't know how good would be to change only one tire...as you said...for grip motivations and safety...but someone will definetely clear your doubt
Old May 11, 2007 | 05:43 AM
chris5150's Avatar
I dont know how you can check the Oil Cold Pilone...my GT3 wont allow a reading until ithe engine is upto running temperature...
Old May 11, 2007 | 05:58 AM
G996's Avatar
Awaiting Email Confirmation
G996 is infamous around these parts
Never, ever check your oil "cold"
Old May 11, 2007 | 06:26 AM
Mussel Kar's Avatar
Mussel Kar is a jewel in the roughMussel Kar is a jewel in the roughMussel Kar is a jewel in the rough
Just get a new tire and take your car to the track. If the track has mostly right turns then put the new tire on the left side. Mostly left turns, put it on the right side.
Cup tires do not have a rolling direction, just an inside and an outside.
There is a very visible difference between my left and right tires after just one track day. Lucky for me I have two tracks to go to. One is mostly clockwise and the other mostly counter clockwise.
Old May 11, 2007 | 07:05 AM
CarraraWhite's Avatar
CarraraWhite is infamous around these parts
Originally Posted by pilone
...check the oil level only when the car is cold...
Originally Posted by G996
...Never, ever check your oil "cold"...
G996 is right on this one, the dry sump motor in the GT3 should be checked hot, NOT cold.
Unfortunately, you should probably to take it to the dealer, it could be a bad sender or other electronic glitch for the reading to jump around like that.
Old May 11, 2007 | 07:15 AM
chris5150's Avatar
Oops just checked the handbook and I see the top bar should be empty...never noticed that, mine is showing all full bars, I presume the car will merely burn off the excess. I should have paid more attention to the handbook before I topped it up.
Its all a bit irrelevent saying never check the oil cold on a GT3, you cant anyway, try taking a measurement when its cold and it wont let you...comes up with the message 'Oil measurment not possible, engine not upto running temp'...
Old May 11, 2007 | 07:56 AM
TT Surgeon's Avatar
1100 miles is not significat, just get one tire for now, if you're really worried you can have the new one (and old one too) shaved, but that's a waste of time on a street car. You'll never notice any significant handling issues with one new tire.
I believe it should be checked hot and running with a dry sump btw.
Old May 11, 2007 | 09:01 AM
Mika_Hakkinen's Avatar
From: So.Cal.- Freeway shooting capital of the world
Mika_Hakkinen is infamous around these parts
Gratz on the new 3! Lets see some pics asap!
Old May 11, 2007 | 11:11 AM
pilone's Avatar
Oh well...I wasn't considering the special GT3 engine...cause that's what I do on "normal" cars...and I was always told to do that. But not on Porsches
Thanks anyway for letting me know
Old May 11, 2007 | 03:47 PM
frayed's Avatar
frayed is infamous around these parts
Just get a new single tire as already stated.
Note that in the owners manual it states in bold not to overfill. Not sure of the repercussions; I did this once in another dry sump car and it simply burned off.
