MPSC in a GT3, mileage
Old May 14, 2007 | 09:40 PM
drqiman's Avatar
drqiman is infamous around these parts
Does anyone have any idea what is the expected mileage for the MPSC in a 997 GT3 used on the street only. Let's assume that alignment, balance and inflation psi are within factory spec. and the car is driven sanely. My rears look like they won't make it much past 3000 and the fronts wil not last much past 5000. Can anyone comment?
Old May 14, 2007 | 10:10 PM
oak's Avatar
oak
change tires when changing oil.
Old May 14, 2007 | 10:12 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Yikes! I thought having to replaces the rears on my G35 at 10k was bad. Good luck!
Old May 14, 2007 | 10:29 PM
GT3 Chuck's Avatar
Administrator
the cup tires are a soft compound and not suitable for street driving if you expect to get any miles out of them...even for track use the car doesn't come stock with enough negative camber to get them to proper temps...if you track your car they will usually heat cycle themselves to death before the tread is gone...any way you look at it...not a good street tire if you don't want to buy a new set every year...unless you intend to track replace them with PS2's...better mileage on the street and better wet performance too...
Old May 14, 2007 | 10:40 PM
SrfCity's Avatar
SrfCity is infamous around these parts
I've heard about 5K. Mine at 1K don't appear to be showing drastic wear so I'd be guessing at about 7K if not more. Street use.
Old May 15, 2007 | 07:21 AM
snowboarder54's Avatar
snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !snowboarder54 Is a GOD !
I first had to change the rears at 3600 miles. The fronts are being replaced today at 6100 miles. Worth every dollar!! Mostly backroad aggressive driving with the exception of one road trip to LA on I-5 from No. Ca!!! Personally I wonldn't change to PS2's, love the stickiness of the cup tires for my type of driving. Have the PS2's on the S and do get about twice the miles out of them on the same roads.
Old May 15, 2007 | 07:44 AM
drqiman's Avatar
Thanks for all the replies. From what snowboarder says, it appears that the rears are good for 3000-4000 and the fronts for up to 6000. I don't have another 911 with PS2's to compare but the MPSC feel very sticky and predictable.
I submitted my queston to another group and I got an interesting reply saying that it is not mileage that counts but heat cycles on these tires. He said that the tires could be toast even on the street before the wear indicators show this. I think he said that about 15 of these cycles, the tires would not have any traction. How do I know how many heat cycles my tires have? Can anyone coimment on this?
Old May 15, 2007 | 08:13 AM
TT Surgeon's Avatar
I think 4k rears and 6k fronts is being very optimistic, if you drive it hard at all you can cut those numbers in 1/2.
Marc's Avatar
Marc is just really niceMarc is just really niceMarc is just really niceMarc is just really niceMarc is just really nice
Street 4k rear 6-7k front.
Old May 15, 2007 | 08:50 AM
lawjdc's Avatar
lawjdc is infamous around these parts
A "heat cycle" on the MPSC tire requires that they be brought up to track operating temperature. I don't think you can do that on the street very well, unless you are absolutely crazy.
Old May 15, 2007 | 09:15 AM
SrfCity's Avatar
I'd be curious to hear mileage for someone who's used the car for normal street use? Anyone had their car long enough and have enough miles to comment?
Old May 15, 2007 | 10:35 AM
TT/T's Avatar
TT/T is infamous around these parts
If not actually, most certainly will feel that way.
Old May 15, 2007 | 05:44 PM
Formula1's Avatar
Formula1 is infamous around these parts
One track session (not track day) = one heat cycle. On the street you won't get a heat cycle unless your on a back country road and carving up the curves. Even on a hot day just driving normally on the road won't get enough heat to consider it a heat cycle.
NC 996TT
Mar 23, 2023 06:19 AM
jaehoppa
Oct 22, 2015 09:17 PM
justthebest
Sep 5, 2015 04:02 PM
hennabav
Sep 5, 2015 12:26 PM
