GT3 / Laguna Seca noise limitations
I had Christian at Carlsen install their mod, it's really elegant, fast, simple and inexpensive. A great solution to do T4-T5 flat out at Laguna. The valve system is only here to make a big mean noise, but keep the valves shut is said not make any difference in performance. I am not deaf enough yet to withstand the always on position.
i have seen j van overbek going up the hill WOT will no prob while i get black flagged behind him.
now i just got to get my car to christian
We have the same problem in the East at Lime Rock PCA events. I used a supertrapp style add-on for my '04 GT3 cup and it worked ok. I am looking into the foam and a tack-on muffler for my '08 GT3 cup. It has a bigger exhaust tip than the earlier cars so not sure if anyone makes anything for the '08 yet.
I found these two possibilities:
Vortex 4" Turndown Cone
http://65.109.249.14/mm5/merchant.mv...nsert-mufflers
And this one which may be better:
Car Chemistry 3DI35L - Car Chemistry Collector Inserts
http://www.jegs.com/i/Car%20Chemistr...DI35L/10002/-1
Or the tack on 90 degree bends with supertrapps but I would like to avoid these.
Also notice the foam sticking out:
that foam plus turn down will NOT get you pass sound at LS, you need supertrap or something more elaborate.
i run my RS with the foam stuffed to wazoo and turn downs... no go
