Does this look too low?
Old Aug 29, 2007 | 03:55 PM
fcracer's Avatar
fcracer is infamous around these partsfcracer is infamous around these parts
Took the car into the raceshop to have it lowered slightly and aligned. I asked for 95mm and 120mm based on the factory measuring points. This represents 13mm or 1/2" lower. I'm surprised at how much of a difference its made in terms of looks. Does it look too low?
In terms of handling, etc., all I've noticed is that it's more stable at high speeds, but haven't pushed it around corners so have no idea if the reduced travel is offset by the lower centre of gravity. I feel no difference in travel from the driver's seat over bumps, etc. It hasn't scraped anything yet so that's not an issue at this time. For alignment, I went with the manual's race alignment of the following measured with all tools and full fuel tank:
Front:
Camber: -2d0m
Toe: 0m
Fender height: 25.5"
Factory measuring point height: 95mm
Rear:
Camber: -2d30m
Toe: 12m each side for a total of 24m
Fender height: 26"
Factory measuring point height: 120mm
Old Aug 29, 2007 | 04:23 PM
NelsonF's Avatar
NelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to behold
Gt3
Looks great and it appears that you've set it up properly. Guards is a beautiful color for a GT3. Well done!
Old Aug 29, 2007 | 04:42 PM
atlshaver's Avatar
atlshaver has a spectacular aura aboutatlshaver has a spectacular aura about
Looks great but the rear may be ever so slightly too low in comparison to the front.
Pipes's Avatar
Pipes is infamous around these parts
I think your ride height looks great....and it sounds like you don't have any handling problems or scraping lift pads because of clearance. I have an old 87 and have lowered it to 24 1/8" at the front fender and 23 1/4" at the rear. It's lower than Euro for this old car, but it handles great.
Old Aug 29, 2007 | 04:44 PM
Mercedes Benz's Avatar
Mercedes Benz is infamous around these partsMercedes Benz is infamous around these parts
Looks great! I plan to do the same to mine soon.
Old Aug 29, 2007 | 05:49 PM
lager99's Avatar
lager99 is infamous around these parts
It looks just as good as I looked in the Roger's box last April.
Old Aug 29, 2007 | 06:29 PM
cor2nir's Avatar
cor2nir is infamous around these parts
I think the ride height looks perfect.
Old Aug 29, 2007 | 06:58 PM
lilstan's Avatar
lilstan is infamous around these parts
It's never too low! I think it looks great!!!!
Old Aug 29, 2007 | 07:00 PM
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
Looks "just right". You'll get used to it.
Old Aug 29, 2007 | 07:15 PM
adybuncio's Avatar
Looks just right, Im 25" all around
Old Aug 29, 2007 | 07:17 PM
Freier's Avatar
Freier is infamous around these parts
perfecto, nicely
Old Aug 29, 2007 | 07:27 PM
IIVVX's Avatar
IIVVX is infamous around these partsIIVVX is infamous around these parts
dont worry, its perfect!
Old Aug 29, 2007 | 07:59 PM
ArcticBoost's Avatar
ArcticBoost is infamous around these parts
I think it looks absolutely perfect, just be careful of the front lip!!
Old Aug 29, 2007 | 08:25 PM
mtalx's Avatar
mtalx is infamous around these parts
Look great. No worries.
Old Aug 29, 2007 | 08:32 PM
Dan's Avatar
Dan
Dan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to behold
I thought the background looked familiar....
Your car looks incredible
