Gallardo e-gear leak
Old Jun 1, 2009 | 05:02 PM
pontevedraguy's Avatar
pontevedraguy is infamous around these parts
My '05 Gallardo egear appeared to have a leak from the hose to the throw-out bearing. I took it to a local Ferrari shop as the Lambo dealer is 2.5 hours away. He replaced the hose and quick connect to the bearing. The banjo-bolt at the other end of the hose looked dry.
Now the hose is saturated again and there is a leak somewhere upstream leaking back down that hose. Any ideas? Can I take off the cover and get to the proximal end of that hose myself??
Thanks.
Old Jun 1, 2009 | 06:00 PM
turbo50mike's Avatar
turbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant future
Thanks.
There was someone with a similar problem, and the leak was coming from the resovoir above. If you take the right side (passenger side) engine cover off, you should be able to see where the leak may be coming from. Or look on the lambo boards for the similar post.
Old Jun 2, 2009 | 05:43 AM
silk55's Avatar
silk55 is infamous around these parts
i had this same problem on my gallardo. except my hose looked frayed. your hose along with hose clamps need to be replaced. also the egear fluid will need to bled. lamborghini should have this as part of a recall or TSB since i know about 5 people with the same issue with 04-05 gallardo's
here are the fallowing parts numbers you will need:
1X 07L115673 PIPE
1X 086325089A PLUG CONNECTOR AND CABLE
1X N0138131 WASHER
1X 086325273A CONNECTOR
1X 980101067 OLIO TUTELA (EGEAR FLUID)
most of it you can get from
http://www.lambostuff.com/xq/asp/yea...catalogTav.htm
awesomebang
Jul 5, 2017 08:48 PM
Jd1368
Oct 16, 2015 09:48 AM
freddiemac
Oct 7, 2015 11:05 AM
