Help help!! Lp560 fluids
Old Jul 12, 2009 | 02:58 PM
vramani's Avatar
vramani is infamous around these parts
Drove car last night when I went to the garage this monring:
1. Only in fender wells
2. Only on passeger front and rear side
ANYONE HAVE ANY IDEAS???
Old Jul 12, 2009 | 03:03 PM
vramani's Avatar
More Pictures
more pictures
Old Jul 12, 2009 | 07:29 PM
turbo50mike's Avatar
turbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant future
Wow. That's bleeding pretty bad. I would assume it is the power steering fluid (looks like it has a reddish tint like the PS fluid they used in previous years).
I believe there is a PS cooler on the passenger side front grill. If I had to guess based on your pictures, this is where I would check first.(It's probably leaking, and then when the fan comes on, it's blowing it all over as you drive).
Either that, or the front lifting shock is leaking - again, I think they are still using the PS pump to activate the lift system. But I don't have a 560 (yet), so I can't give you any more help...
But it's an 09...So right back to the dealer for you...
Old Jul 13, 2009 | 08:55 PM
vramani's Avatar
dropped it off today on flat bed.
Old Jul 14, 2009 | 06:24 AM
Cool. Keep us posted on what they find.
Old Jul 14, 2009 | 08:46 PM
vramani's Avatar
Outcome
Thank you to Lamborghini Houston for being pros!
So after all of this NOTHING it seems that I must have drove over an oil spill??
Old Jul 14, 2009 | 08:48 PM
Were you driving behind the Exxon Valdeze???
Old Jul 14, 2009 | 09:55 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Sure looks like it!
Old Jul 14, 2009 | 11:10 PM
SiNzz's Avatar
SiNzz is infamous around these parts
Thankgod for AWD traction ; you must not even have noticed you drove over one! Glad to hear nothing's wrong with your ride.
Old Jul 14, 2009 | 11:11 PM
vramani's Avatar
I am just as puzzled? They said all lines are fine and the fluids they use are clear?
Old Jul 16, 2009 | 03:53 PM
12:03's Avatar
12:03 has a spectacular aura about12:03 has a spectacular aura about
my initial reaction before reading the thread, was that you drove though some soda pop syrup or something on the ground. mainly due to the location in the fender wells, and being all contained to one side
Old Jul 16, 2009 | 04:03 PM
911A4Mustang's Avatar
911A4Mustang is infamous around these parts
only one way to be sure... you should taste the fluid. if it's sugary it's pop, if you get violentally ill you should call the dealership... oh ya seek medical attention.
Glasgo
Nov 30, 2015 02:37 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
TOGWT
Detailing
Sep 28, 2015 08:25 AM
