Lambo Gallardo Issues?
Old Oct 10, 2009 | 07:48 AM
Rfong's Avatar
Rfong is infamous around these parts
Squeaky brakes
Originally Posted by GT650-25
common issues of older cars 04 05
Egear...get a 6 speed
Brakes...Work great but can be noisy ($500 fix)
Plugs but rarely ($1200 to fix)
GT650-25
I saw your comment about noisy brakes and the $500 fix.
I just got an 08 Gallardo and the brakes squeal LOUDLY when coming to a stop. What is the fix?
Of course, Dealer says it is normal??
Old Oct 10, 2009 | 08:29 AM
MrEdS4's Avatar
MrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud ofMrEdS4 has much to be proud of
Clutch life can be short depending on driving habits, (can exceed $1 per mile)
Rear main seals leak
Other seals leak but not as badly
E-gear can take getting used to but at anything but creeping traffic, is a lot of fun
Rearward 3/4 visibility is very poor
If you want to change your own oil, the filter is very tough to get to
Brakes have been good
Tire wear has been acceptable
Best to stay on top of servicing
Electrics on early cars can be difficult - lots of systems communicating in strange ways
They get better with age if maintained properly
Air conditioning can be a bit weak
They require a lot of voltage to start. The batteries don't drain badly when sitting but If the voltage gets low after several starts, sometimes the transmission does not get the power it needs to mess around pre-start.
Each one has its quirks but once you know them, they are great cars.
Our 04 is about to turn over 38k miles. Still running strong!
Old Oct 10, 2009 | 01:08 PM
djantlive's Avatar
subscribed.
i am also interested in the remark about brake noise and the fix for it.
is the transmission ratio improved in 2006 or 2005?
how does 2009 LP560 drive compare to 2006-2008 G?
Old Oct 10, 2009 | 08:23 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
Great thread
Old Oct 10, 2009 | 09:31 PM
997SilverTurbo's Avatar
997SilverTurbo has a spectacular aura about997SilverTurbo has a spectacular aura about
I just get my Gallardo 2 month ago, and the only problem was the stock exhaust system, is so heavy and i hate the noise, now i put tubi and is a lil better, but i still want a lil more loud but is ok for now.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
pjb84
Sep 2, 2015 12:57 AM
