Lowering my car
Old Aug 2, 2011 | 08:41 PM
yellowbull's Avatar
yellowbull is infamous around these partsyellowbull is infamous around these parts
Lowering my car
Does anyone if u can lower a gallardo
Old Aug 2, 2011 | 08:42 PM
Perdition's Avatar
Perdition is infamous around these parts
Yes.
Old Aug 2, 2011 | 09:04 PM
yellowbull's Avatar
Can u use the factory coil overs? Or do u need to change any thing?
Old Aug 2, 2011 | 09:10 PM
Perdition's Avatar
What year is the car?
Old Aug 2, 2011 | 09:39 PM
yellowbull's Avatar
2007
Old Aug 2, 2011 | 09:43 PM
Perdition's Avatar
2007
You're in great shape then. The stock coilovers are adjustable. You have a range of about 2.5 inches of adjustment.
yellowbull's Avatar
I brought my car to a place that did my tt and asked them to lower my Lambo about an inch all around because I was changing my wheels. They told me that they couldn't because it was already at the lowest setting. I found that strange because I know someone else that has one and he said he just had it lowered with the factory stuff in there
Old Aug 2, 2011 | 09:45 PM
yellowbull's Avatar
Thanks I thought so.... Guess I have to find a new place maybe they just got lazy
Old Aug 2, 2011 | 09:52 PM
Perdition's Avatar
No problem. I'm not sure how low your car is now but it may be worth having another shop take a look at your G.
Old Aug 2, 2011 | 09:54 PM
yellowbull's Avatar
I have to find someone now thought I could trust these guys
Old Aug 3, 2011 | 12:26 PM
roncfpz's Avatar
roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !roncfpz Is a GOD !
You might already be at the limit of the factory springs. You may have to get shorter springs to lower it more than factory springs/coilovers allow. I swapped out the factory springs with shorter/stiffer springs from Swift on the factory coilover and problem solved.
Old Aug 3, 2011 | 01:40 PM
vividracing's Avatar
Swift makes en EXCELLENT spring. Just make sure you don't get go too low, or you could end up damaging your dampers.
There's also the option of aftermarket coilovers. KW makes a set, and I'm sure Ohlins or Moton also do.
-Matt
Old Aug 3, 2011 | 08:39 PM
mtmd11's Avatar
mtmd11 is a jewel in the roughmtmd11 is a jewel in the roughmtmd11 is a jewel in the roughmtmd11 is a jewel in the rough
Good thread, thanks. I've been considering having mine lowered an inch to 1.5''. I've really liked the look of others' Gallardo's that are lowered.
Old Aug 5, 2011 | 08:00 PM
yellowbull's Avatar
Ok..... I had my car dropped today and it looks great. I put 20 inch rims on it and bringing it down made all the difference
Old Aug 5, 2011 | 08:02 PM
yellowbull's Avatar
Enter Content
