E55 Supercharger Belt Replacement
Old Feb 7, 2008 | 02:56 PM
trojanman's Avatar
Welcome to the OC, bitch!
trojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant futuretrojanman has a brilliant future
My service writer told me the belt is supposed to be replaced every 20,000 miles and my car is already at 25,000.
It's about a $220 part. I could not find any mention of this in service manual (or perhaps I glanced over it).
Is this normal or is my service writer ripping me off?
Old Feb 7, 2008 | 03:10 PM
Johnfromjersey's Avatar
Johnfromjersey is infamous around these parts
Generally belts can be found in any size at any NAPA store. Do you happen to know a part number for this? If so, they should be able to cross reference this.
I also just hit 25,000 on a my 55. So If this is true I guess I am due for a replacement as well. Pls keep us updated on any info you find out. Thanks
Old Feb 7, 2008 | 03:26 PM
Tuskir's Avatar
Tuskir has a spectacular aura aboutTuskir has a spectacular aura about
The belt is actually like 130 bucks from NAPA, Mercedes is ripping you off. Just get the dimensions and go buy one yourself.
P.S. If you're replacing it anyway, you might as well get a stage 1 upgrade w/ pulley and belt from Renntech, Kleemann, or Evosport. Get an extra 50hp or so.
Old Feb 11, 2008 | 11:38 AM
trojanman's Avatar
I had the service performed last week as recommended. The $220 (approximately) included labor, so I guess it wasn't that big of a ripoff.
Still, I have yet to find any literature anywhere stating the belt replacement is mandatory.
Old Feb 11, 2008 | 11:39 AM
trojanman's Avatar
Yeah but if you think MB dealers rip you off, Renntech & the like charge about 1000% over cost on crap like this.
Old Feb 11, 2008 | 01:27 PM
Tuskir's Avatar
That's 100% true, but at least its worth it in this case since you're picking up 50hp or more. ASP pulley is also very popular and its only like 200 bucks.
Old Feb 12, 2008 | 09:07 AM
Broadway Performance's Avatar
Broadway Performance is infamous around these parts
I pay under $100 for the belt and can change it in about 30 seconds or so. $220 is a rip. I'd do it for free if you were local.
John
Old Mar 6, 2008 | 08:52 PM
sunilp@motorwerks's Avatar
sunilp@motorwerks is infamous around these parts
the belt is very easy to replace with a 17mm wrench. It is part of scheduled maint. since it slips easily after it ages.
Old Mar 7, 2008 | 10:02 AM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
Yeha, popular because its cheap, then people realize that in this case, cheap=crap. Then they buy a VRP, Renntech, or Kleemann.
Old Mar 7, 2008 | 10:11 AM
dferg476's Avatar
dferg476 is infamous around these parts
Hey, I work parts at an MB dealer and I'm seeing it listed for $66. $220 might be with labor or something.................the PN I came up with is 011 997 97 92 and the belts demensions should be 21.36X2390.
Hope that helps.
DGF
Old Mar 7, 2008 | 10:13 AM
dferg476's Avatar
I don't know about all the pulleys, but we had one come in here with a renntech on it and it might have been improperly installed, but it came loose and shifted the crank inside the housing and destroyed the whole engine.
the engine alone was something like $45K
Old Mar 7, 2008 | 12:20 PM
Improperly installed. Ive never seen a properly installed one come loose. Someone probably reused the crank bolt, which is not smart at all.
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
PelicanParts.com
Aug 21, 2015 01:37 PM
