2009 Mercedes-Benz SL63 AMG
Old Feb 8, 2008 | 05:25 PM
NAPO's Avatar
NAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to beholdNAPO is a splendid one to behold
For 2009 Mercedes-Benz unveiled a fourth member of its iconic SL sports car family – the SL63 AMG. Perhaps the sportiest SL roadster ever, the new SL63 AMG is powered by a 6.3-liter, all-AMG V8 engine that’s coupled to a newly developed MCT transmission. Featuring an innovative start-up clutch that replaces a conventional torque converter, the seven-speed MCT (for multi-clutch technology) transmission combines the direct connection of a manual gearbox with the lightning-quick automatic gear shifts of a Formula 1 race car. Topping off the SL chassis is an even more agile AMG sports suspension based on the Mercedes-Benz ABC active suspension.
MCT Transmission – The Best of Both Worlds
Providing the direct feedback of a manual transmission with the total convenience of an automatic, the new seven-speed MCT with AMG Speedshift is an all-new design available only in the new SL63 AMG. Featuring seven speeds, four shift modes and a double-clutching function, the MCT transmission offers impressive versatility and even faster shift times.
At the heart of the new AMG Speedshift MCT seven-speed sports transmission is a new start-up clutch, which runs in an oil bath and replaces a conventional torque converter. Thanks to its low rotational mass, the start-up clutch helps the transmission respond instantaneously and dynamically with no slip.
Fitted with four drive modes: “C” (Comfort), “S” (Sport), “S+” (Sport plus) and “M” (Manual), the transmission provides customized shift control for maximum driving pleasure, and does so with no interruption of power. In Comfort mode, smooth shifts coupled with a “soft” accelerator response are set up for silky smooth power transfer. In Sport mode, the engine and transmission interact quicker – upshifts and downshifts take place at higher engine speed. Gearshifts are around 20 percent faster than in Comfort mode. Switching to the Sport Plus mode cuts another 20 percent off shift times, while the sportiest mode, Manual, reduces shifting times by another 10 percent – a total reduction of 50 percent compared with Comfort mode. In Manual mode, the gearshifts take just 100 milliseconds.
Ultra-fast, spontaneous multiple downshifts are another forte of the new MCT sports transmission. For instance, kickdown will shift directly from seventh down to fourth gear or from fifth to second. In the “S” (Sport), “S+” (Sport plus) and “M” (Manual) modes, an automatic double-clutching function is active. Every manual or automatic downshift is accompanied by precisely metered double-clutching – from “S” through “S+” to “M” incrementally. Not only does double-clutching make driving more fun, but virtually load-free downshifting minimizes any jerking, a special benefit when braking into a curve.
The First Engine Developed From the Ground Up by AMG
The SL63 AMG is powered by an AMG 6.3-liter V8 engine that features four valves per cylinder, variable valve timing, bucket tappets (rather than rocker arms) and a variable intake manifold. Sharing no parts with Mercedes-Benz V8 engines, the 6.3-liter engine was a completely autonomous development at AMG.
Built almost completely from a high-strength silicon-aluminum alloy, the cylinder bores make use of a twin-wire-arc-sprayed (TWAS) coating, a process that results in impressively low friction and running surfaces that are twice as hard as conventional cast-iron cylinders.
The 6.3-liter engine block boasts an especially rigid bedplate acting as the overall support of the main bearings (similar to a one-piece set of main bearing caps), cast-in steel reinforcements and a sturdy closed-deck layout in the cylinder head area. The high-flow intake and exhaust ports form a vertical straight line, helping the 6.3 AMG engine rev freely to more than 7,000 rpm, yet the highly flexible AMG engine still produces nearly 90 percent of its peak torque at only 2,000 rpm.
A finely balanced crankshaft with six counterweights spins in five main crankshaft bearings. The crankshaft counterweights feature heavy metal plugs – a detail usually found only in racing engines – which means they can be significantly smaller, increasing power by reducing rotational inertia and oil drag.
Each forged connecting rod is precisely “cracked” with the help of a laser beam, so the irregular fracture contributes to its strength when the two halves are clamped around the crankshaft. The connecting rods and lightweight pistons are matched for extremely close weight tolerances that contribute to smooth running at high speeds. Small nozzles in the engine block spray cooling oil onto the underside of each piston crown.
“Bucket” Followers Instead of Rocker Arms
Twin overhead camshafts in each cylinder bank open the 32 valves via bucket-type followers. In other words, instead of rocker arms, the cam lobes sweep across the flat top of the followers, which sit directly on top of the valve stems. This space-saving design provides a very stiff valve train that allows for large valve openings and dependable high-speed operation for maximum horsepower and torque. However, in contrast to racing engines, each bucket incorporates a hydraulic lifter that automatically maintains valve clearance, which allows for long service intervals and low costs.
The AMG V8 makes use of variable intake and exhaust valve timing to maximize efficiency and torque over a wide RPM range. Valve timing can be automatically adjusted within a range of 40 degrees using electro-hydraulic vane-type adjusters on each camshaft. At part throttle, the valve timing adjuster keeps the exhaust valves open as the intake valves are opening, using this valve overlap for internal exhaust gas recirculation, reducing exhaust emissions and improving fuel economy. However, approaching full throttle, the camshaft adjustment optimizes valve timing for maximum power. The intake cams are driven by a double chain from the crankshaft, and small gears on the intake cams in turn drive the exhaust cams.
Unique Styling Touches
The SL63 comes with a distinctive AMG front hood that’s noticeably different from other SL models, as well as a new front apron with a more pronounced wedge shape, larger cooling air intakes, and a black grille. Bi-xenon headlights with black surrounds and large round fog lights ringed in chrome and set well to the side emphasize the vehicle's width.
Hot air from the engine exits through side air outlets in the front fenders and from the “gills” behind the front wheels. Trim panels finished in matte silver with “6.3 AMG” lettering catch the eye, as do new outside mirrors with arrow-shaped LED turn indicators.
SL63 AMG body styling also includes deeper AMG side sill panels and a beefy-looking rear apron that incorporates a large black air diffuser and two pairs of chrome tailpipes. An AMG rear lip spoiler on the trunk lid reduces lift, especially at high speeds.
Finished in nappa leather and genuine carbon fiber, the interior features standard AMG sport seats, an AMG three-spoke steering wheel and a sport instrument cluster with red tach and speedometer needles that swing to the max position and back whenever the ignition is turned on.
From Coupe to Roadster in 16 Seconds
At the push of a button, the SL’s retractable hardtop can be fully opened or closed in just 16 seconds, transforming the car from a quiet, weather-tight coupe to a top-down open-air convertible. A hydraulic pump and 11 computer-controlled hydraulic cylinders power the system, and roof operation is controlled by a switch on the center console. A clever folding design allows for a surprisingly large cargo area of 7.2 cubic feet when the top is down. With the top up, the trunk holds 10.2 cubic feet.
High-Performance Braking
Excellent stopping power for the SL is provided by large, four-wheel disc brakes enhanced with four-channel ABS anti-lock control. Matched to its power and speed capability, the SL63 AMG comes with large 14.2-inch vented rotors up front and 13.0-inch vented rotors at the rear, while the SL65 AMG boasts vented discs that are another 1.2 inches in diameter.
Also new are 19-inch AMG staggered-width alloy wheels – 8.5 and 9.5 inches wide – fitted with 255 / 35 R 19 (front) and 285 / 30 R 19 (rear) tires. With triple-spoke styling and a titanium grey finish, the AMG alloy wheels complement the new AMG body styling.
ABC Active Suspension
The SL chassis uses a fully independent, double-control-arm front suspension and the patented Mercedes-Benz five-link rear suspension. All SL models come with second-generation Active Body Control (ABC), the Mercedes-Benz active-suspension technology that virtually eliminates body roll in cornering, squat under acceleration and dive during braking.
Each SL uses software programming specific to the model, akin to tuning the spring rates, shock damping and roll stiffness of a conventional suspension. Special AMG struts with firmer damping and fully reworked systems such as ABS anti-lock brakes, Brake Assist, ASR traction control and ESP stability control complement the enhanced AMG chassis.
Mercedes-Benz engineers use ABC’s interplay of hydraulic, electronic and mechanical parts to reduce body roll by 68 percent (compared to the same vehicle with a conventional suspension), providing the driver with needed feedback through the vehicle chassis. A ‘Sport’ switch on the center console can make it 95 percent reduced roll, along with tighter shock damping. Active suspension solves the usual tradeoff between ride comfort and handling precision, so SL roadsters offer excellent comfort and league-leading handling.
Link:
http://www.fast-autos.net/vehicles/M...009/SL_63_AMG/
Old Feb 8, 2008 | 05:26 PM
NAPO's Avatar
Old Feb 8, 2008 | 05:29 PM
mbphreak's Avatar
mbphreak is infamous around these parts
Not diggin' the daimler front-end...
ew.
Old Feb 8, 2008 | 06:47 PM
Cedric's Avatar
Cedric is infamous around these parts
not bad, but why didnt they re-design the rear end?
It looks like a current SL with a new front clip added to it
AeroTT's Avatar
AeroTT is infamous around these parts
i think that looks sick!
Old Feb 8, 2008 | 07:29 PM
jstrat85's Avatar
jstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to all
not bad i like it! and those mirrors are sick!
Old Feb 8, 2008 | 11:53 PM
doccao's Avatar
doccao is infamous around these parts
Looks stunning! But not enough for me to upgrade anytime soon (waiting for Black Series SL). Will enjoy my current SL55 until the 3rd refresh model perhaps in 2010?
Old Feb 9, 2008 | 01:32 AM
v35's Avatar
v35
v35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond repute
That looks pretty hot. However, the front looks so nice at an angle, but not so nice when looking at the front directly.
Old Feb 9, 2008 | 02:41 AM
RT8_M3's Avatar
RT8_M3 is infamous around these partsRT8_M3 is infamous around these parts
Doesn't look bad at all, starting to grow on it now but just hate those headrests....
Old Feb 9, 2008 | 03:02 AM
rammie's Avatar
rammie is infamous around these parts
i think mb has overdone it this time trying to make their current cars look like their old classics. the headlights look out of place, and it's a shame they didn't re-design the rear end as cedric mentioned.
Old Feb 9, 2008 | 10:43 AM
997TTBOY87's Avatar
997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts997TTBOY87 is infamous around these parts
They didn't redesign the end because it's just a facelift.
Old Feb 9, 2008 | 01:19 PM
NAPO's Avatar
Old Feb 9, 2008 | 02:00 PM
MJC123's Avatar
Senior Member
MJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud of
I skimmed it but no mention of power?
Old Feb 10, 2008 | 10:19 PM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
anyone think pre-update is better looking? For now, i do think so, but im sure as time goes on, it shall look dated and this one will look better... happens (almost) all the time (old 5 series, still better looking then new 5 series)
Old Feb 11, 2008 | 11:53 AM
Vladcanada's Avatar
Vladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of lightVladcanada is a glorious beacon of light
you know at first I hated it, but now I think it kinda does flow with the car and looks good.
