Pulley Upgrade = Running Lean?!
Old Aug 16, 2007 | 07:33 PM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
[edited_ ]
Old Aug 16, 2007 | 07:58 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
I have no idea what your factory pulley is vs the 165mm.
However, yes, they are correct. Do not up reduce the pulley size without engine management software. If it is fact only 10hp, you can probably get away with it. At which point I would say why bother? It's only 10hp. If you are pumping a lot more air in with a smaller pulley and your ECU can't adjust for the changes you will have big problems with detonation. Don't cheap out. It's a nice car.
Old Aug 16, 2007 | 09:31 PM
rflow306's Avatar
rflow306 is infamous around these parts
You can do a search on Mbworld , there are several guys running the ASP pulley which is larger than 165mm with a factory ecu. The ecu will adjust some for the increased boost, typical gains are 40 to 50 rwhp with a pulley swap alone. If anything the ecu tune is only good for 10rwhp after the pulley install. They tend to run very rich from the factory.
If you are not going to be installing headers or other power enhancing mods on top of the pulley you will be fine with the factory ecu tune.
Old Aug 16, 2007 | 11:01 PM
ROCKETW19's Avatar
ROCKETW19 is infamous around these parts
yes i agree 100% with rflow you will get 30-40rwhp with pully alone and maybe another 10rwhp with ECU. i seriously would not use that shop that told you, you will only get 10 hp outta a pully alone. either they are stupid or they are tryin to get more money outta you. either way i would search for another shop.
what are your long term goals with this car? are you just addin more spice to it or are you gonna go all out stage 5?
Old Aug 16, 2007 | 11:08 PM
996TTDave's Avatar
[edited_ ]
Old Aug 16, 2007 | 11:44 PM
DFW911T's Avatar
DFW911T is infamous around these partsDFW911T is infamous around these parts
Absolute garbage.
My car runs richer.
A/F flattens out at 10 pretty quickly.
50+hp and 80+ft lbs for $1,200.
https://www.6speedonline.com/forums/...ad.php?t=70925
Search on ASP pulley or get the new VRUS pulley tensioner kit on the E55 forum on MB World.
Run lean? ... tell us who they were.
Old Aug 17, 2007 | 12:40 AM
996TTDave's Avatar
[edited_ ]
Old Aug 17, 2007 | 12:44 AM
ROCKETW19's Avatar
renntech told you that? as in renntech in florida? or a supplyer of theirs? holly **** that is crazy.
Old Aug 17, 2007 | 12:49 AM
996TTDave's Avatar
[edited_ ]
Old Aug 17, 2007 | 12:58 AM
ROCKETW19's Avatar
wow he is full of ****! at least he said possabilty of runnin lean. but still full of ****. their liquid pully is the latest greatest thing out i will give them that. but i wouldnt go with them after that e-mail. also in case you didnt know evotech does all of renntechs ECU tunning.
Old Aug 17, 2007 | 01:13 AM
996TTDave's Avatar
[edited_ ]
Old Aug 17, 2007 | 01:25 AM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
They use a silicone fluid to dampen vibrations from the engine(from combustion). Basically, its to save bearings and the crank from some wear and tear.
Old Aug 17, 2007 | 04:57 AM
Why wouldn't you use an adjusted ECU with this package?
Old Aug 17, 2007 | 07:01 AM
rflow306's Avatar
Originally Posted by 996TTDave
where can one go about purchasing this ASP pulley? Thanks
You can purchase from here http://www.k1motorsport.com/.
You should also look into the new Evotech pulley or wait for one of VRUS's new multi-piece units. I have had the ASP pulley on for a long time with-out a single problem but if I had to do it all over again it would be one of the above. (just my 2 cents).
FYI: The ASP, Kleeman and old Renntech are all modified stock MB balancers. I forgot about Evosport they make one from scratch which also looks very good.
Old Aug 17, 2007 | 08:14 AM
DrivenAgain's Avatar
Site Sponsor
DrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond reputeDrivenAgain has a reputation beyond repute
renntech is clueless and doesnt even develop half the products they sell, bob brady will tell you anything
